-   -   How to get less noise from a targa top (http://forums.pelicanparts.com/porsche-911-technical-forum/593929-how-get-less-noise-targa-top.html)
prebordao 02-26-2011 09:07 AM
This is probably old knowledge but...
My targa top has always done the usual cacophony of noises when on the move.
In the last week I started to think that most of the noise seemed to be of rubbing between the top and the front and aft rubber seals. Removed the top, tried a generous smear of petroleum jelly on the seals and went for a ride... Success, most of the noise has gone !
Now let's see how long it lasts...
DRACO A5OG 02-26-2011 11:21 AM
Use Di-electric Grease ( Silicon Based Paste Grease like 3m Silicon Paste, will rejuvenate the rubber parts ) at the rubber corners where it meets the rear and front seals, the pins and the pin receivers. I do this every 2 car washes, it really keeps her quite.
You can use the paste on the front rear seals, but if those are squeeking you have other issues, that is a sign of bad seals or worse bad latching mechanism/s. The latch and pins should keep enough pressure to keep those seals quite, it is normally the pins and pin receivers that rub and squeel.
Jim
