Less brakes, more gas!
Before you say get a new alternator... I did... and I had the old one rebuilt... same problem. So...
I have pulled out the electrical diagram and the systems seems very simple as far as the battery/alternator is concerned. There is a Red/10 wire that goes from B+ to the starter at the same terminal as the big honkin' Blk/25 cable from the battery. I believe this is how the alternator charges up the battery. My trouble shooting ideas:
Ideas? Thanks for your help in advance! -Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
83 911 Production Cab #10
Once you start the car, the voltage on the battery should be up not down.
Have you got an External Voltage Regulator? If so, I would suspect it.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
This may be too simple but have you confirmed that the bulb for your alternator light is good? It needs to work to "excite" the regulator, thus resulting in the alternator putting out a charge (although I'm no expert in these matters).
Keith |
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Chief Head Scratcher
+1 Before you start the motor, make sure that the alt light is on with the key in the on position.
John Morris '79 911SC |
Banned
So, external regulator or not ?
Its an internal regulator.
I didn't even consider the bulb... meh its a bulb... Damn that F****** bulb! Who knew it was an on/off switch for the alternator! WTF? The whole car can be disabled by a single bulb? The light does not come on with the key so I'll swap it out with a spare and see if she charges. It always glowed at idle and I thought 'Damn! I finally solved the glowing at idle problem I have had for 17 years! Cool!' *Face Palm* Seems I am now in possession of a spare alternator... Lets hope its the bulb or I'll be calling you all wankers for getting my hopes up!
I just recently replaced battery and a bad alternator. Following replacement, all the lights, including the dash lights, were brighter.
Several days later the Alt light doesn't come on. I'm thinking WTF? Bad alternator rebuild? Nope. The fresh alternator was too much for the old bulb and it killed it. I was relieved when a new bulb took care of that problem.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Is it the same type of bulb as the other dash bulbs?
Kurt |
An '82 I believe is a 4 watt bulb. I have a '75 that takes a 2 watt, same as other dash lights except I put a 91 ohm resister in parallel on the light because I have a new alternator that is internally regulated.
Hope for you it is the bulb! Keith |
QUOTE=luskesq;6753250]An '82 I believe is a 4 watt bulb...[/QUOTE]
Correct Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
Thanks for the info on the bulb - probably wouldn't be a bad idea to keep a spare.
Kurt |
HAHAHA you guys are lucky! Oh and very helpful too! Bulb was blown... replaced and now I have a nice new charging system! YEAH! Now I can charge off to Sebring for the weekend without fear of being stranded on some 2 lane highway in the middle of no-where central florida... if you have been there you know what I am talking about!
As a side note, I now have a rebuilt alternator with 0 hours on it Thanks again for the tidbit of knowledge that had escaped my 17 years of ownership with the car!! -Michael
Good to hear it is working! Enjoy Sebring!
Aren't simple fixes great! Glad for you and have a great weekend.
Keith |
Spoke to a top line mechanic, Klub Sport, he mentioned that 'those' alternators are iffy at best to repair. Bought a NEW alternator, Valeo. Installed. No charging.
OOOPPS! He should've known that it could've been, and most likely was the bulb.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
"Spoke to a top line mechanic, Klub Sport, he mentioned that 'those' alternators are iffy at best to repair."
The '82/'83 911SC Paris-Rhone (Valeo) alternator is a marginal alternator and unreliable compared to the earlier 911SC alternator (Marchal).
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
Banned
BTW, what was the alternator on a 74' ? Marchal or Motorola ?
"what was the alternator on a 74' ? Marchal or Motorola ?"
They both look the same and were both used (2 alt sources), another weak Porsche alt.
