i need a 98mm ring set, uncommon thickness
i'm looking for a set of factory mahle rings for a 3.2 big bore kit to fit a 3.0. the pistons are mahle 98mm max moritz wedge style, and the ring thicknesses are 1.2mm, 1.2mm and 3mm. pete at andial should have some in early february, but i could use them sooner. jerry woods, ebs racing, ssf, supertech, no luck. anyone have some or know where to look? not too big on using other brands like j&e, hastings, etc.
bump for the morning crowd.
I would rather be driving
John,
I had a custom set made by Total Seal for my 98mm Mahle RSR pistons. Turn around time was just a few days. They will need land thickness and cylinder bore measurements. They came with the end gap preset (and correct) to my specs. Two years now and they are running well. Contact: Keith Jones Total Seal Inc. Ph 623-587-7400 800-874-2753 Fx 623-587-7600 keithj (at) totalseal (dot) com remove spaces and replace symbols
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Chain fence eating turbo
OMG, I am in the same boat.
Did not want to read this......
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
+1 for Total Seal on the hard-to-find stuff.
I got a set of their rings for my 91s... |
Cory,
The cost is not really any different that a stock set of rings. Give them a call.
Yeah, Don at EBS got them for me.
Thanks |
what i ended up doing was getting a set of 98mm X 1.5/1.5/3mm from EBS racing and had my friend jeff hines cut the ring grooves to fit. seems that 1.2 thickness is not readily available. turns out they were goetze too!
I called a machine shop and was told a piston manufacturer would have to do it. Luckily, Don from EBS gets Total Seal to make conventional ones in this size. He actually had some in stock recently but I missed the last set. He said it would be a few days before they are made again.
he gets them from peter @ andial, who gets them from mahle. i waited six weeks for those with no end in sight and finally had to get creative, so good luck. i guess you need a better machinist.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 03-04-2011 at 05:37 AM.. |
Oh great....
