Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
3.0 track car rebuild
Couldn't pass this one up, so a friend and I went in together on this project. 78 911 euro race car, motor was killed when fan belt let loose on the track.
Lots of go fast goodies, the guy must have lived with the Automotion catalog in his pocket. Weltmeister sway bars, solid engine mounts, autopower roll cage (EEEEKKK!!). Cool bits, the wevo shifter and cv joint for shift coupler.
Big problem is the motor...82 sc block, puking oil everywhere. 100% leak down, heads and exhaust. Gaps between heads and cylinders. This got cooked.
It had the top end done recently, it's a shame...
When the pistons get too hot, the rings break and the aluminum melts. Busted ring bits do this....
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 02-24-2011, 05:32 AM
John,
The car looks like it was as described, impressive work getting it torn down already. Looking forward to checking it out when I drop off my SC on Friday.
Old 02-24-2011, 06:24 AM
Stahlwerks.com
jhelgesen's Avatar
Thanks, tear down is the easy part, reassembly is the tough part without breaking the bank.
Old 02-24-2011, 07:38 AM
dtw dtw is offline
GAFB
John, are the heads bricked? Looks like it.
Several BMWs
Old 02-24-2011, 07:51 AM
Stahlwerks.com
jhelgesen's Avatar
Just the one head is dimpled, maybe fixable. Prob have to redo all the valve guides for safety.
Maybe someone has a spare or two 82 3.0 head laying around?
Old 02-24-2011, 08:00 AM
Stahlwerks.com
jhelgesen's Avatar
Oh, oil pump may have ingested a ring tidbit. I can see a notch in a gear through the output opening.
Old 02-24-2011, 08:02 AM
Stahlwerks.com
jhelgesen's Avatar
Case came apart this weekend...cleaned up well.
Cleaned up the worst head, looks salvageable. Dinged a few exhaust valves though, so they will be replaced.
Oil pump gear has a groove, still need to tear it down.
John Helgesen
Old 02-28-2011, 08:41 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
question about the dinged up head... Will that be potential hot spot for detonation? I have heard that any rough spots could cause some trouble.
thanks for posting.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 02-28-2011, 09:58 AM
