-   -   Timming Chain Cover Removed * While I'm in there? (http://forums.pelicanparts.com/porsche-911-technical-forum/595188-timming-chain-cover-removed-while-im-there.html)
JJ 911SC 03-05-2011 09:38 AM
So, I'll be changing the gaskets, O'rings for Banjo Bolt receiver (actually the left cover came out too easily).
Anything else?
What is the "plug" for, beside the Banjo Bold hole on the covers?
http://forums.pelicanparts.com/uploa...1299346663.jpg
http://forums.pelicanparts.com/uploa...1299346703.jpg
JJ 911SC 03-05-2011 09:45 AM
Oops... Post too fast
Anything else?
http://forums.pelicanparts.com/uploa...1299346977.jpg
http://forums.pelicanparts.com/uploa...1299347008.jpg
http://forums.pelicanparts.com/uploa...1299347097.jpg
Gunter 03-05-2011 12:21 PM
Not sure what you mean But make sure to install new small O-rings on the shaft for the banjo fitting. They seal the hole in the covers. Old seals leak!
JJ 911SC 03-05-2011 12:27 PM
Originally Posted by Gunter (Post 5883756)
Not sure what you mean But make sure to install new small O-rings on the shaft for the banjo fitting. That seals the hole in the covers. Old seals leak!
Hey Gunter
Yeah, the 2 seals are comming. Actualy the right one was leaking.
I meant, is there anything else I should check & what is that plug on the cover (4th photo)?
JJ
Flat6pac 03-05-2011 01:31 PM
#4 picture, plug is the support for the pin that the tensioner sits on. It is only pressed into place and then sealed from leaking on the pin side you cant see.
Bruce
cgarr 03-05-2011 01:41 PM
You could add the internal tensioner stops at this time. Its a good safety items should it ever fail.
BK911 03-05-2011 02:08 PM
Verify / adjust cam timing.
JJ 911SC 03-05-2011 02:48 PM
Bruce
Thanks, I notice there is a black "cement" in the inside to seal it.
Craig
Never heard of this... But then again. I'll use my friend the "search".
BK911
Haven't done a Valve adjustment yet... So maybe next time.
JJ
Flat6pac 03-05-2011 03:46 PM
The right cam gear looks completely worn out in the picture.
Bruce
BK911 03-05-2011 04:04 PM
JJ: While you are that close, I personally would not button it up without adjusting intake valves 1 & 4 and verifying cam timing. You are sooo close already! In fact, I would adjust all the valves. Cant hurt.
Bruce
Holy poop, I didnt notice that!! Good catch,
RoninLB 03-05-2011 04:21 PM
could be over 100k miles?
I'd probably spend a couple of hundred $ in there to buff it up if i was going to keep it
nice pics
JJ 911SC 03-05-2011 04:25 PM
Bruce
Bruce
That is why I posted... I will take some close-up pics.
Any measurement I should do or you can just eyeball it?
There goes my April 1st date...
BK911
So you are saying to do the Valve adjustment without seal the covers, not a problem since it look like I'm deeper than O'ring and seal :eek::D:eek:
RoninLB 03-05-2011 04:44 PM
i'd advance the cams as much as possible
....... but that's just me
JJ 911SC 03-05-2011 05:01 PM
OK, let me have it... At least they seem even.
Right: CAM Sprocket: ~5mm Lifter Sprocket: ~6mm
http://forums.pelicanparts.com/uploa...1299373099.jpg
Left: CAM Sprocket: ~5mm Lifter Sprocket: ~6mm
http://forums.pelicanparts.com/uploa...1299373189.jpg
JJ 911SC 03-05-2011 05:07 PM
nice pics
The car is barely over 65k miles (odometer and government recording from day 1) but the engine is anybody guess???
6th and last owner so its a keeper :):D:)
RoninLB 03-05-2011 05:08 PM
I'm no expert
Pelican# 901.105.546.02.M260
http://forums.pelicanparts.com/uploa...1299373720.jpg
James Brown 03-05-2011 05:13 PM
They look fine, i think it was the picture lighting that everyone thought was worn out chain sprockets. However, it looks like the lower chain on the left side is cracked through.
J/K, carry on.
Cam timing advancement can help with low end or high end depending where you set them (+-) but only a degree ether way, be carful.
JJ 911SC 03-05-2011 05:26 PM
J/K, carry on.
James
I wont be playing with advancement...
I don't see what you are referring to about lower chain on the left side is cracked through it even sound worse then worn Sprocket
James Brown 03-05-2011 05:40 PM
It's just a joke, :D:D:D:D:D feel the love?
JJ 911SC 03-05-2011 05:45 PM
Actually... I started to think that you were talking about the chain breaking trough the light.
I can feel it (love) :) but I made another trip to the garage :D:):D wont bother to post the photo
