Rebuilding a ZF Limited slip
I have a ZF limited slip (fine spline) that I ran in my 72 911. I replaced it with a TBD for autocrossing. The ZF did fine at first. It launched really hard with both tires spinning. Over time it got to the point where only one wheel would spin at launch. I assumed theat the clutches were worn and removed it. This is the later model LSD with only one clutch per side. When I disassembled it, the clutches did not seem to be worn very badly. Any advice on critical measurements on the component parts as well as where to get replacement parts. Thanks,
Tom
1972 911T (with 3.2), 1985 930-EFI Conversion (in progress), 2016 Cayman GT4
Old 01-28-2011, 09:30 AM
Grady Clay's Avatar
Tom,
Reassemble it just the way it was and measure the torque necessary to have each clutch slipping. This is done with an (inexpensive) indicating-type torque wrench and not a click-type.
You can easily calibrate the torque wrench by clamping the ½” drive in a vice and hanging known weights from the handle.
I suspect you will find the torque out of spec.
This is why the 1-disc/side LSD is barely suitable for anything other than generating heat.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 01-28-2011, 09:37 AM
The ZF diffs with single plate/disc per side usually require 7-25 lb-ft torque to break the clutches, when tested as shown below (better with ring gear and bolts fastened). The outer plates were available in 3 sizes: 1.9mm, 2.0mm and 2.1mm. The housing flange can also be shaved, but it shortens the diff and requires a new preload/backlash adjustment.
Jon B.
Vista, CA
Old 01-28-2011, 10:20 AM
Sell the late ZF so-called "snow-only" diff, use a 40/65 LSD set up for maximum clamp (~70 ft/lbs of torque) and marvel at how much more planted and controllable the car feels on acceleration and deceleration...
'77 S with '78 930 power and a few other things.
Old 01-28-2011, 05:02 PM
Geary's Avatar
Originally Posted by Tom Oxner View Post
This is the later model LSD with only one clutch per side. Any advice on ... where to get replacement parts.
When Porsche began making discs and plates in half-thickness (in order to squeeze twice as many active discs into their GT3 LSDs), Guard Transmission did the same with both late style and early style discs & plates. Matt @ GT can easily rebuild your later ZF with 4 active friction discs.
Old 01-29-2011, 09:35 AM
Thanks for the advice. I had already done the "torque wrench test" and found that the amount of torque required was less than that specified in the factory manual. I will give GT a call to see what they have. Thanks for the help,
Tom
Old 01-31-2011, 09:30 AM
ZF Repair
Can I have Matt's number as well. Thanks, AO
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 03-05-2011, 07:09 PM
0396's Avatar
sub.. interesting
Old 03-05-2011, 08:20 PM
