87 carerra, smog-test with pre-muffler?
i have an M&K pre-muffler on my 87 carerra and I am due to have car smogged. Anyone have any experience or advice with this. I'm not sure if it is worth getting car really hot and having it tested, or just to go ahead and install cat converter back in before. Any advise would be a big help.
Old 02-24-2011, 07:20 AM
muck-raker
kidrock's Avatar
mixed bag of responses. Some have passed w/o the cat, some have failed.
I would change oil, air filter, adjust valves, connect brown wire @ DME and put in stock chip (if replaced). Drive until hot, test immediately.
YMMV
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-24-2011, 07:31 AM
RETIRED
Joe Bob's Avatar
pretest it.....
2012 ML350 3.0 Turbo Diesel
Old 02-24-2011, 07:36 AM
depends where you are testing, I can't pass with bypass, have to install cat once every 2 years.
Old 02-24-2011, 07:47 AM
Senior Advisor
James Brown's Avatar
You can get a cat and swap out the premuffler for the test.
08 Cayenne Turbo
Old 02-24-2011, 08:13 AM
Send a message via Skype™ to hangar21
mtb001 is correct, it depends on what state you are being tested? My 87 is in Texas, 2011 test do NOT require emissons testing. I would check your state regs and have a pre-emissons check.
Old 02-27-2011, 06:31 PM
vracer's Avatar
How big a deal is it to put the cat back on? (Not the cat-back ;>)
Richard
1989 Venetian Blue Targa
Old 03-06-2011, 05:42 PM
9 bolts hold the cat or pre-muffler in place. Amount of rust/corrosion depends on how long between tests. I've had to do it every year here so not too bad. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 03-07-2011, 06:50 AM
Diss Member
Quicksilver's Avatar
Stainless bolts with copper nuts and the change isn't a big deal.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-07-2011, 07:18 AM
in WA state i had to reconnect the o2 sensor wire, it was unplugged by the PO for some reason i don't know cause idle seems to still be good.
ken
87 targa
Old 03-07-2011, 07:44 AM
Nine9six's Avatar
...other than the $30 in cat & exhaust gaskets.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 03-07-2011, 09:12 AM
cattman's Avatar
I, too, have an upcoming test here in ATL, and my plan was to put the original cat back on, for the test, and then put the bypass back on afterwards.
Is it necessary to remove my Wong chip for this brief period?
Must I use new gaskets, too?
2005 Porsche 911: 997S, supercharged to 530HP
1987 Porsche 911: Concours prep OEM guards red on black
Old 03-07-2011, 12:07 PM
RETIRED
Joe Bob's Avatar
Depends on what your State decides on the limits. If as tough as CA, probably not. That's why it's recommended to pretest.
Old 03-07-2011, 12:11 PM
Roc Doc's Avatar
It won't pass the visual test. The cat has to be in place.
I have a 76 that was originally sold in WA, so I have a nice Non-Catalyst sticker in the door jamb, so I can get my 3.2 to pass without the cat in place, but an '87 is going to have to use the cat.
1976 911S Targa, Carrera bodywork, 3.2l engine.
Old 03-07-2011, 01:08 PM
I ran a bypass on my 1987 (well over 140,000 miles) and passed every year with room to spare until Houston TX began checking for NOx. Even with Daugherty cams I passed all but NOx. The mass air flow probably helped clean the exhaust. I'm guessing Atlanta is checking NOx.
1987 Guards Red Targa, cams, exhaust, MFI intake, lowered, 7 and 8's, 200,000 plus miles of smiles
Old 03-07-2011, 01:48 PM
