stephens_kj's Avatar
Corner rubber rear bumper strips on SC.
Are these only held on in two places? I have managed to unbolt the thread that holds the bellow end of the strip round the corner so on the side of the bumper. The only other place I can see where it is held is under a little rubber hole bung, but when I removed the bung the only stuff in there was rust particles.
I don't want to re use the old strips so am I ok to get a bit macho with them and prise them off with brute force or are there any more fixing points that I should know about first? I would have carried on the investigation but ran out of time and now at work.
Thanks and sorry if you have been asked this before, and I know it would help with pics but I have not got any yet, although I will check what I have on photobucket.
Thanks for any help offered people.
Ok have pic now.
The red area is now undone, and the bung hole in the green area is what is just full of rust particles.
Someone has already suggested that there is indeed a third fixing under the bumperette?
Thanks for info peeps.
1983 911 SC 3.0
1978 Ford Capri X Pack 3.0
SE OM Flyer 2011(26), SE PK Ripper 2010 Retro Loop(20), Mongoose SGX 1999 Anniversary(24)
Est 1971
Old 03-08-2011, 10:27 AM
On my US SC I recall there was a screw on the end that tucks under the bumperette.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 03-08-2011, 10:31 AM
No screw, it just tucks under the bumperette.
Bruce
Old 03-08-2011, 10:35 AM
Also the small panel that is the other end of the bellow and is attached to the bottom of the rear fender by 3 self tapping screws. The last one is unreachable, am I needing to remove my rear lights to get access to the last screw?
Thanks people, no better place to ask these questions.
1983 911 SC 3.0
Est 1971
Old 03-08-2011, 10:42 AM
