Early-s Man / Need Help
I took my pedal cluster apart to rebuild it and
discarded the plastic spacer I should not have. Now I need to know where it goes exactly. The diagram Pelican sent with the rebuild kit does not show it and neither does my 101 book. Can you help me figure out where it belongs. It's been so long since I took it apart I just don't remember. Thanks K.T. 1973 911E 2.4 MFI ktaylor@stinson.com |
Kevin:
The plastic bushing is the first thing on the clutch pedal shaft BEFORE you slide the shaft into the pedal assembly. Hope this helps.
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
Is it the red bushing in this pic?
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?threadid=57957 |
Re: Early-s Man / Need Help
OK, thanks a bunch you guy's.
Will disassemble and get it right this time. Thanks K.T. 1973 911E 2.4 MFI ktaylor@stinson.com |
