-   -   HELP!!!!! Spring Arm to Trailing arm missing bolts (http://forums.pelicanparts.com/porsche-911-technical-forum/595877-help-spring-arm-trailing-arm-missing-bolts.html)
Mingus 03-09-2011 07:19 AM
I can where the washer and bolts once were... Odd thing is they are missing on both sides. Anyone else ever experience this? The PO had lowered the car prior to my purchase, I wonder if they just forgot the top trailing arm to spring plate/arm bolts? I am assuming they are necessary, although I haven't noticed any problems in the 6000 odd miles I driven in the last 2 years.
Thoughts? Should I install the m12 1.5 35mm bolts, washers and nuts on the top (i think those are the specs of the bottom ones). Flange bolt?
http://forums.pelicanparts.com/uploa...1299683780.jpg
http://forums.pelicanparts.com/uploa...1299683802.jpg
See my rebuild here at http://forums.pelicanparts.com/porsche-911-technical-forum/595520-my-911-sc-minor-overhaul.html
Mingus 03-09-2011 08:01 AM
anyone????
Danny_Ocean 03-09-2011 08:12 AM
I just checked my car. Bolts are there. Aren't those bolts used for adjusting rear alignment? Perhaps a hung-over alignment tech forgot to install them.
I would just install some bolts and go.
Bob Clucas 03-09-2011 08:12 AM
Absolutely you should put those in, that's what holds the whole thing together!
Bob
pete3799 03-09-2011 08:26 AM
Put them in ....ASAP!
bkreigsr 03-09-2011 08:30 AM
I found out mine was loose on one side when I did an autox. the car had a mind of it's own.
yes replace asap .... Bill K
Mingus 03-09-2011 08:56 AM
Thy will be done...
boyt911sc 03-09-2011 09:19 AM
PM or Post your shipping address.....
Originally Posted by Mingus (Post 5890973)
anyone????
Mingus,
I have several OEM nuts and bolts sitting in my garage. Take care of the shipping cost and will send you two (2) sets or more. FedEx if you need ASAP or flat rate box from USPS ($5) would take care of the shipping expenses. Let me know your decision. I could have them ready by tomorrow.
Tony
Flieger 03-09-2011 11:06 AM
The alignment one are in the middle of the spring plate. The bolts connecting the banana to the spring plate are both necessary.
Chuck Moreland 03-09-2011 09:44 PM
You shouldn't drive the car till those are replaced.
It is likely your alignment settings have drifted. I would have the alignment checked.
Danny_Ocean 03-09-2011 10:02 PM
If they're not used for alignment, why are they slotted?
Walt Fricke 03-09-2011 11:29 PM
Well, they are used for alignment.
If you adjust the toe, things have to slide fore or aft. If you adjust the camber, one sort of goes one way, and the other the other way. So for an alignment they are loosened, the adjusters are turned so things are where you want them to be, and then these are tightened back down. One of the adjusters serves to clamp the front of this business also.
On my track car I use old 12mm flywheel bolts with some matching nuts I purchased. Those are strong suckers. But any 8.8 or better 12mm bolt of about the right length and nut (with appropriate washers - not flimsey fender washers) would do.
Mingus 03-10-2011 05:26 AM
replaced with 10.9 12mm 1.5 35mm last night
thanks for all the help. chuck, i will be getting the alignment checked as i am readjusting height after taking out all heat, a/c, stock exhaust for headers, cis for bitz efi...i've already sacrificed enough weight that i'm a little high in the rear end...(that didn't sound good)
Jdub 03-10-2011 06:52 AM
Late to this discussion but it seems obvious that the car was lowered by amateurs and they left out the bolts to accommodate the bodge. Since you are probably replacing all the bushings anyways (spring arm; bannana arm, drop links, etc.) you will have ample opportunity to fix this. By the way, the car will be transformed with this basic suspension R&R with bushings that old.
I have done this on my '78 and it is pretty straighforward - you can do this yourself for certain.
Mingus 03-10-2011 06:57 PM
whats a bodge?
Flieger 03-10-2011 07:37 PM
A repair/upgrade job done to a low standard using questionable engineering and/or materials and performed by a "hack mechanic".
Mingus 03-11-2011 08:31 AM
thanks max
KTL 03-11-2011 08:40 AM
Some M12 bolts, a washer each for the bolt head and the nut, and a lock nut can be had at your local hardware store. Ace Hardware typically has a good selection of metric. For that connection where a lot of force is supported, a minimum of a 10.9 class metric bolt should be used. I'm sure Ace has 12.9 allen head bolts that would fit that location no problem.
Not trying to diminish the charity of Tony's offer to send you some. Just saying there's got to be some local source up there in cheeseland! :D
Mingus 03-11-2011 09:03 AM
flatlander
thanks kevin. i picked them up already (truvalue rather than ace). got flange bolts in 10.9, stainless flat and lock washers and hex and nylock stainless nuts. think i should use nylock or hex and lock washer?
KTL 03-11-2011 09:25 AM
I'd use just plain steel washers and nuts. When you mix stainless and non-stainless, the differing materials can induce corrosion and the threads gall. Plus the stainless washers might collapse a bit when you torque the nuts to spec, as the stainless washers are usually a bit thin.
I like regular nuts and lock washers myself. The nylocks are techincally supposed to be a one time use only. But i'll admit i'm guilty of reusing them alot. The factory nuts are actually neither plain nor nylock. They're deformed thread all metal locknuts. But any of the three will work ok. It's not like these are removed very frequently.
Back to stainless.......not always a good choice because while it's hard, it's not as strong as some of the basic grade steel fasteners. I looked up the specs of multiple grades of stainless M12 hex head bolt and all had a lower ultimate strength rating than just a basic M12 8.8 property class screw.
The flange bolts are nice. I like using those wherever I can. If you had a serrated flange (mechanical locking surface underneath) in 10.9, i'd say you found a real nice choice. Just use regular steel nuts, plain with lock washers or nylock, and you'll be all set.
Walt Fricke 03-11-2011 11:40 AM
Sounds like good advice about not mixing steel types.
But if you torque these fasteners to their specification they won't come loose. Lockwashers, whose value is questionable (see Carroll Smith's book on fasteners, AKA Screw to Win), aren't necessary. If they were, my stuff would have come loose long ago. It doesn't.
The one place where nylocks come into their own, I think, is valve covers (or anywhere else with that kind of gasket). Those take minimal torque (and when you exceed that you risk warping things) and have a crushable gasket between them and the clamped surfaces. So having that kind of "friction on the threads" device makes a lot of sense. Suspension fastening isn't of that sort.
KTL 03-11-2011 02:03 PM
I agree with Walt that the lock washers are questionable. If nothing else they're a belt & suspenders sort of arrangement- overkill or extra peace of mind? The split washers seem like they do have some benefit. The spring/wave washers are suspect IMO since their locking effect is pretty small, especially if reused (which they're technically one time use).
The nylocks are great on the valve covers for sealing too. The crush washer seals at the cover interface and the nylon seals the threads to prevent drips. But reuse on the lower covers and you usually end up with drips from the threads. Upper covers rarely ever leak so you can reuse those nylocks, and the gaskets, several times. I have so many extra upper cover gaskets it's silly!
