Buying 86 arrera that was sitting 7yr
Need to know the gotchas on a Carrera I am planning to buy that sat around for 7yrs. Driven only occasionally. I will have it PPI but what should I expect and look for?
French Import
Of course I could beat a dead horse and say "use the search feature" but that would be rude...!
![]() Anyway, for what I have read here and on other forums dealing with vehicles that sit for a long time here are the highlights: Drain all fuel and clean out tank replace oil and filter, transmission fluid clean/replace air filter Clean/replace spark plugs you may need to pull and clean the injectors of course you will need a newer battery and clean the terminals That would be to get the engine started. Then replace brake fluid/ and possibly flex lines, replace tires so you can be safe once you get the car on the road... That should be enough to get your heart pumping... and then go down the slippery road of refreshing just about anything that is 24 years old!!!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Much mahalos
French Import
Let us know the PPI results.
Can you post pictures of the car? If the engine is actually running you will be ahead of the game. You should add details on your profile, such as your location, and maybe a local member knows the car you are looking at or would be willing to take a look at it with you. You will find a wealth of knowledge on this forum!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate Last edited by zippy_gg; 03-10-2011 at 08:27 PM.. |
