-   -   quick question on install of new struts (http://forums.pelicanparts.com/porsche-911-technical-forum/595981-quick-question-install-new-struts.html)
rsswesley 03-09-2011 04:05 PM
1982 sc with bilsteins. Received the new inserts and the directions that came with them say to use molyb-denum grease in-between the sliding bearings. My question...where is the location of the sliding bearings.
Chuck Moreland 03-09-2011 10:28 PM
Remove the old inserts from the struts. Then peer into the struts, you will see two linear bearings. One near the top, the other about 8 inches down. The outer surface of the inserts rides against these.
