pete3799's Avatar
camber measurements
I made a camber gauge out of a 2 foot aluminium carpenters level.
I drilled and tapped the side of the level and screwed in 2 bolts.
With the bottom bolt screwed all the way in i use the top one to adjust for level.
So here's were i need help......
Fronts are both at 1/4 inch negative camber. The bolts in the level are at the top and bottom of the 16 inch rim (16 3/4 inches on center)
How do i convert my 1/4 inch to degrees. I was absent that day or my dog ate my homework..........can't remember.
Bonus question
The rears are both at 9/16
Pete
79 911SC RoW
Old 06-10-2012, 03:47 PM
What's Facebook?
turborat's Avatar
Get your trig book out or use this link Trigonometry Calculator
Turborat
"’Cause every once in while, the lion has to show the jackals who he is”
1979 911 SC - 2100 LB track rat
1986.5 928 5-Speed - 36,000 miles
2001 330Ci
Old 06-10-2012, 05:12 PM
I got 0.59 degrees for .25" negative camber. Cool calculator!
Old 06-11-2012, 08:36 AM
cycling has-been
bkreigsr's Avatar
or, you could pull the trig-ger (sorry) on one of these...and theY are magnetic...
Bill K
Digital Torpedo Level- Craftsman-Tools-Measuring, Levels & Stud Finders-Laser Levels
Old 06-11-2012, 10:56 AM
