jluetjen's Avatar
Installing Wiring Loom Bullkhead Connectors
I'm in the process of replacing the burnt out wiring loom in my 69E. I've figured out how to get the circular bulkhead connectors out, but I'm having a hard time getting them installed. Is there a trick? I've tried pushing straight in, and starting one end and working it in, and neither approach has met with much success. I'd be interested in what others have found works.
Thanks!
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-12-2011, 12:20 PM
I use a heat gun on low setting to warm them up. With heat the plastic gets more pliable and you can get them in using a turning motion.
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 03-12-2011, 12:54 PM
soapy solution worked for me
Old 03-13-2011, 06:09 AM
kodioneill's Avatar
Rubber lube or silicone.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-13-2011, 06:13 AM
jluetjen's Avatar
Thanks. Using a combination of both of those approaches the connector slid right in. Thanks!
John
'69 911E
Old 03-13-2011, 03:15 PM
