-   -   Carrera Tail or Duck Tail... (http://forums.pelicanparts.com/porsche-911-technical-forum/5965-carrera-tail-duck-tail.html)
makaio 07-11-2001 03:31 PM
I'm trying to decide between a Carrera Tea tray style tail or a Duck Tail. I like the look of the 911 without a tail, but I need the extra downforce. I already have the front spoiler. What is everyones comments? Which do you like better?
Matt Chamblin
78 911 SC
BlueSkyJaunte 07-11-2001 03:45 PM
Duck tail looks cooler (IMHO) but produces greater drag. Really. All aftermarket ducktails that I've seen are a complete decklid replacement.
Carrera-type tails do not create as much drag but typically require drilling--so either get a spare decklid and attach your tail to that or sacrifice your pristine original one to the Downforce Gods.
I don't know if there's a difference in downforce between the two.
Personally I think the ducktail looks better on pre-'74 vehicles and the Carrera looks better on post-'74.
YMMV.
blue
'81 SC Targa
mark 74 carrera 07-11-2001 03:47 PM
Duck. But I am biased. My car came with the duck tail.
Mark Isaak
'74 Targa
911pcars 07-11-2001 04:02 PM
Between the two, the duck tail produces less downforce. Actually, downforce is sort of a misnomer as both reduce lift rather than create downforce. The end result though is the same, and that is to keep the rear end planted at high speeds, the "tea tray" does a slightly better job.
http://www.pelicanparts.com/ultimate...s/513431-B.jpg
Appearance wise, it's your call.
Sherwood Lee
http://members.rennlist.org/911pcars
Jack Olsen 07-11-2001 04:18 PM
<font face="Verdana, Arial" size="2">I like the look of the 911 without a tail, but I need the extra downforce.</font>
Click on this thumbnail to see one alternative solution:
http://members.rennlist.com/jackolsen/Feb01C-RE2.jpg
Downforce when you need it, and the fastback look when you don't.
Jack Olsen
My Rennlist home pageMy Pelican Gallery pageMy Porsche Owners Gallery page
[This message has been edited by JackOlsen (edited 07-11-2001).]
Bill Verburg 07-11-2001 05:04 PM
Lift and drag are variables which move in step with one another, when one goes up so does the other, and vice versa. Sherwood Lee is correct the spoilers available for use on a 911 do not provide downforce, they only reduce lift(and drag) to varying degrees. Since this effect is most observable at speed, here are the lift #'s in lbs. for the 3 most common early types all at 150 mph
ducktail ~160
Carrera ~150
3.3 liter Turbo ~85
no spoiler ~295
The corresponding front #'s are
ducktail ~60
Carrera ~50
3.3 liter Turbo ~40
no spoiler ~145
ps great pic Sherwood! You really got all the ductails in a row!
pps I always liked the esthetics of the ducktail, its also lighter.
rscupper 07-11-2001 05:17 PM
I think the 'whale' tail (~'79 turbo?) would look great on an SC. I had one on my '74 Carrera & my previous '75 Carrera. Excellent aero advantage on the track and looks well proportioned with the rear flares. Otherwise, the 'sugar scoop' is a classic. Yep, your design call.
pwd72s 07-11-2001 05:33 PM
Deck lid spoilers? Heck, you guys just want to take all the fun & excitement out of doing 150! The whale tail is cool tho. Gives you a place to put your McDonalds lunch while dining out. I've often thought I should add one to my car. http://www.pelicanparts.com/ultimate/wink.gif
RaF944 07-11-2001 06:29 PM
Its also a wonderful beer holder when you are drinking outside http://www.pelicanparts.com/ultimate/wink.gif
85.5 Porsche 944
[This message has been edited by RaF944 (edited 07-11-2001).]
Mikkel 07-12-2001 03:55 AM
http://www.fvd.de/katalog/aerodynamic_de.html
In my opinion the 1978 Turbo 3.3 spoiler is the best looking of them all. However it sometimes look a bit inappropriate on narrow SCs and Carreras. For a SC/Carrera I'd recommend a Carrera whale tail. Ducktails look best on pre 1974 cars.
BTW my 1984 Carrera has no rear spoiler.
JohnnieA 07-12-2001 06:21 AM
Duck!
gaijinda 07-12-2001 06:27 AM
I am no purest, but I like the duck tail on the lighter bumber '73 and earlier cars. For a '74 and later 911 I would go for the whale tail.
Roland Kunz 07-12-2001 10:59 AM
Hello
The Duck tail is the most efficient unit aviable.
The unit does not add additonal "face surface" to the car and lowers the CD while helping to pump air into the engine bay.
But Porsche hit a bad nerve with that and german burocracy forced them to make the new rubber liped spoilers. ( In fact each ducktail needed to have a single approval by TÜV, some costumers got there RS with a normal lid and the ducktail as a race track only item )
So they changed to the later style.
They needed to be much more wide and overstanding ( and add face value ) for thesame effect. The rubber lip will distord under high speed ( especially the aftermarked sold "flubber lips" ) and lower effectiness ( this is why race wings have no rubber tip ). Also the newer units have more wight.
Now with the 964, Porsche came back to the ducktailsystem. The TÜV will not allow to use that system without selfaktivation and as you can not ecedd 60 km/h in reverse it is legal ( Well the issue is runing against a child while backing up, the edge will hit the head ). So if you retrofit the 964 unit the TÜV will see the unit goes up and down like the original unit. A knob that lets you rise the unit must be overrided if you drive the car. A not working 964 spoiler gives you a bad point at the TÜV inspection and has to be fixed. Either if it will go up or not down. The good thing is they don´t testdrive to find out. But if you really run against a child while backing up ( this happens often as childs are not acting normal and you have no direct view ) or a bicycle driver hits you and the spoiler adds injurys you would be glad to have investet a handfull dollar more and have it done the right way.
Now if you say the RS came with a fixed wing then look close all RS came with a full working wing except the CUP with wasn´t a street legal car.
The general idear is to raise the upper windfiollevel as hig as possible following Wunibald Kamm´s researches ( Known as Kamm heck ).
Generally it says the longer the car the higer it´s speed ( or lower drag ).
This is theer reason why the 964 wing does not only drive up it also goes far back.
Grüsse
makaio 07-12-2001 11:20 AM
Thanks all! I have decided to go with the Duck Tail, even though my car is not the early body style. I've seen a couple of SC's with them, and they look good. Even with the bumper bellows.
Matt Chamblin
78 911 SC
911pcars 07-12-2001 11:44 AM
How much lift is reduced with this rear spoiler?
http://members.rennlist.org/911pcars/MartiniRossi.jpg
Sherwood Lee
pbs911 07-12-2001 12:00 PM
Duck, Duck, Carrera
Paul
78SC Targa
jsmarcus 07-12-2001 12:34 PM
How about using this "whale tail"?http://www.pelicanparts.com/ultimate...oads/whale.jpg
Josh
Black on Black '84 Carrera
Bill Verburg 07-12-2001 02:26 PM
Keep in mind LIFT AND DRAG are inextricably linked. The type of link is called direct variation when one goes up the other does also. Do not confuse with coefficient of drag or frontal area which are different, though related concepts. Here are the factory published graphs of lift.
FRONT
http://www.pelicanparts.com/pmpre/im...ront_small.jpg
REAR
http://www.pelicanparts.com/pmpre/im...rear_small.jpg
The reference to turbo is the early turbo spoiler which is quite similar to the SC/Carrera spoilers. The other references are self explanatory.
stealthn 06-26-2002 08:54 AM
Bill,
Thanks for the graphs, that's great!
What are the ramifications of just the front spoiler, I know you would eliminate the front lift, but does this increase this in the rear?
I know Porsche says to do them at the same time (Front and rear spoilers), but I have a Targa (yet another wind flow issue), and I never really liked a tail on a Targa. I have added front spoilers on other cars and this really helps in the front end, so I'd like to add the "smile" to mine.
Each to their own with tails, IMHO I like the appropriate tail for the years, but I like the turbo tail better than the Carrera tail on the 78-87 years.
Cheers
island911 06-26-2002 09:13 AM
Originally posted by Roland Kunz
Hello
I previously believed this. . .seems logical for a spoiler to have minimal "wetted area".
However, the efficiencey of the tails is dependent on the shape of the car. From Paul Frere's book the early turbo/carrera style tail work best (is most efficient) on the 74-89 bumpered 911's.
. . It's not just the best looking ;)
