topcarbon's Avatar
ideas to make more significant horsepower.
I have a 1977S with a 2.7l motor. I have dual 40mm carbs instead of the cis injection.
How can I increase the horsepower on my car where I can notice significant changes?
Will a 46mm or 50 mm carb system do the trick, or am I asking for trouble?
I don't want to change out the engine, and want to work withwhat I have.
Am I asking the impossible?
Looking for ideas.
THanks
Old 03-14-2011, 04:38 AM
topcarbon's Avatar
Originally Posted by JastionRock View Post
How can I increase the horsepower on my car where I can notice significant changes.Will a 46mm or 50 mm carb system do the trick, or am I asking for trouble..
so, is this the answer? Or are you playing with a novice 911 owner?
Old 03-14-2011, 05:03 AM
JastionRock:
This is the second post (see also S-hose thread).... I see where you simply copy and repeat something said in a previous response within that thread.....what's goin' on friend???
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-14-2011, 05:11 AM
IROC's Avatar
One idea that most people don't consider is leaving the engine alone (and that is a beautiful engine) and changing the gearing in the transmission. A 7:31 ring and pinion (or simply installing an entire gearbox from a '72 to '74 911 would effectively add horsepower for far less $$ than tearing into the engine.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 03-14-2011, 05:18 AM
I assume JastionRock is not a real person, but a computer that posts randomly in an attempt to sell his Chinese wares.
Anyway, back to the OP's question.....
Old 03-14-2011, 05:48 AM
a.k.a. G-man
Geronimo '74's Avatar
Originally Posted by Wil Ferch View Post
JastionRock:
SPAM, only want his hyperlinks posted
(reported to mods)
Old 03-14-2011, 05:57 AM
Home of the Whopper
Or get a lower profile tire.
Or do both!
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 03-14-2011, 05:59 AM
Racer
winders's Avatar
Is it just me or do those wing nuts look out of place in there?
Scott
Old 03-14-2011, 09:37 AM
Or lose some weight on the car....or simply noodle on some serious suspension mods. Quickens the over-the-road sensations w/o doing engine mods.
Wil Ferch
Old 03-14-2011, 10:20 AM
tobluforu's Avatar
Wing nuts or not, that is one hell of a clean engine and bay-looks like it's never driven.
Old 03-14-2011, 10:26 AM
A large bank account helps. In fact, for significant power increase, the bank account is essential.
There is no easy solution without significant modifications. Increasing the engine displacement has been known to provide good results.
Sherwood
Old 03-14-2011, 10:27 AM
Zeke's Avatar
You have the wrong pistons and cams in that engine to do much. Bigger carbs will get you nowhere. To work with what you have, put the CIS back on and get a turbo kit. There are a few reliable ones built by members here.
Old 03-14-2011, 10:36 AM
Tom '74 911's Avatar
Looking for ideas.
I have a '74 911. I am replacing the engine, which was a strong running 2.7L CIS motor, with a 3.6L engine for more HP. I did quite a bit of research and while I would have loved to stay with my 2.7L motor, there aren't really any "bolt on" type things you can do to significantly increase the HP. Even w/Carbs, you really need to do P&Cs and cams to realize a big difference. Once you start digging into an engine, especially a mag cased 2.7L, it's hard not to spend A LOT of money when your primary goal is more HP.
If you're looking for significant HP change, either swap a larger disp. engine in or expect to spend big $$ on upgrading the internals of your 2.7L.
Alternative courses could include gearing and weight loss - both of which would most likely be more affordable than engine work.
Nice looking engine bay BTW!
All the above is just my opinion of course - but I've been exactly where you are and asked the exact same questions!
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 03-14-2011, 10:46 AM
tobluforu's Avatar
^^^ What he said, sell that motor which looks like a piece of art, take money add to it, buy a 3.6 and put that in it.
Old 03-14-2011, 12:49 PM
Under the radar
Trackrash's Avatar
As long as you don't have to worry about smog checks there are a couple of things that can be done for modest gains.
Back dating the exhaust to the pre-74 type system should help.
Those zenith carbs may need bigger venturis as well.
Otherwise pistons and cams will be needed to see any real gains in hp.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-14-2011, 12:54 PM
Senior Advisor
James Brown's Avatar
3.6 should do it
08 Cayenne Turbo
Old 03-14-2011, 01:47 PM
Originally Posted by James Brown View Post
3.6 should do it
3.2 and 3.0 too.
If you DIY on your engine (RS P/C, more aggressive cams, head work, etc.), should be worth an extra 40-50 HP for <$6K. YMMV. Remove some extraneous weight and it should be pretty responsive.
Sherwood
Old 03-14-2011, 02:13 PM
On my 3.0L, at the same time on mine I did a shortened gearbox (stock 1st, short 2,3,4,5), SSIs / Sport muffler, and slightly shorter tires all at the same time.
Made a big difference, and less expensive than the rebuild route probably.
The gearbox and tires will work just fine if I do the 3.6L later too, where messing with the current engine would be higher lost value.
And weight makes a huge diff too, though looking at that engine compartment, a lot of stuff is already lighter there (no sound pad, etc.), so the rest of the car may already be...
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 03-14-2011, 03:21 PM
topcarbon's Avatar
thanks for all the help. Ive driven the car one weekend, for the first time last weekend. Before, it sat waiting for me to return to the States. I will be driving it more. I have lots of suspension mods already, so maybe lightening will be the way to go.
Or, I could always leave it.
Old 03-14-2011, 04:28 PM
MBruns for President
JeremyD's Avatar
Sell the car and buy a turbo.
Or change the transmission for an earlier car with a 7.3 to on gearing. I can't imagine a 2.7 with the later 8.31...
Old 03-14-2011, 04:37 PM
