"Proper" way to shift a 3.2 Carrera
A couple of nit-picky questions about shifting:
1) What's the best rpm range to shift up on this G50 transmission? The engine starts to "scream" at 3000 rpm, but from what I hear the real power comes after 4000 rpm 2) After you put the shifter in the next gear, do you ease the clutch out COMPLETELY before adding gas, or do you start adding gas AS you're releasing the clutch? I've been easing the clutch out completely, but notice the rpms spike as soon as it "grabs". On this note, is it good to apply gas and "rev-match" before releasing the clutch? 3) Double-clutch - any 3.2 drivers who do this? Thanks in advance.. |
Hi ,
Yes , clutching out totally is needed. I practice the double clutch , but not very usual with G50 gearbox. That can help in some situations when gearbox is hard to shift , or used , or cold. But in normals conditions , not necessary. Just my 2 cents. |
Thanks for the reply.. again, after putting the shifter in the higher gear I need to slowly clutch out completely before applying ANY gas. Shouldn't do both at the same time.
I've been reading up on double clutching, and it seems like something to do while downshifting from 5th to 2nd gear, for example - clutch out with shifter in neutral momentarily before shifting into 2nd gear. It's supposed to match engine and transmission RPM and help "save" the transmission. Also, is "rev matching" needed in this G50 gearbox when shifting or downshifting? |
On the up shift you should apply gas slightly and let the cluctch come until you feel it bite.
This is standard for any manual and applies to any car. 1st gear will get you comfortably to 20mph/32kmh and then into second. The way you shift depends on what you are doing. On the street driving conservatively you will probably select 3rd at 30mph 4th at 40 and 5th at 50or 60mph. On the track the gear remains in longer and the rrpmīs go up. G50 have a syncomesh so many would debate the need to double clutch at all. I personally heel and toe on the downshift under braking. |
(like Twistoffat said) |
I always thought that the proper way to shift in any porsche was to start off in first gear rev until just before the rev limit, depress the clutch, engage second gear and then release the clutch pedal while applying full throttle!!
Then apply the same technice for the following gears untill you arrive at the next corner! :D |
Under full throttle I generally double clutch on the upshift (freeway on ramp etc)..it just seems smoother to me.
Under partial load, with a G50, it doesn't seem necessary on the upshift for casual driving. The transmission seems to like being shifted at a certain cadence...there is definitely a G50 sweet spot when engaging the gear that can be felt. The clutch engagement is rather high in the throw so I find myself initiating the shift just as the pedal it coming into the bottom of the arc and therefore the the transmission has already declutched fully. Throttle response is not terrific so I do have the gas coming down before totally clutched, but depends on how fast I am shifting. Out of habit I double clutch on nearly every downshift, even when shifting into first as a coast to a stop. I'd be interested to know who double clutches on the upshift regularly. |
I'm VERY gentle on my G50,..not too often redlining 1st gear. I take my time getting to the subsequent gear,..sometimes DC'g.....just making sure I don't "feel" anything within the shift,..that way I know the gears are happy.......never speed shift (?)
As an aside (and I don't know what thread I picked this from,..but was from a knowledgable P-guy......when dead cold (startup)...I always position 3rd gear BEFORE I position #1 gear.......the guy referred to it as "staging" the gears.... (WTF?)....makes for an easy entry into 1st. I baby my G50....yet rev matching is a must!!!!!!!! Doyle |
double clutch on the upshift is nonsense
double clutch on the downshift is optional Rev match aka heel and toe on the downshift is essential To optimise shifting, adjust the clutch stop so that the pedal only travels far enough to separate the clutch. |
shifting
so what is screaming? mine just came out of winter hibernation and it doesn't scream at 3000. 4500 + maybe...
this winter i replaced the chip with S. Wong (previous was a P ??? model). and it is so much more calm and consistent. the last 2 days i drove it to work and every gear smooth shift 4000-4500 and normal slow or medium acceleration. it gets going well above 3000.... go enjoy it. stock chip? the S wong one is well worth it and i do hear differences with it. it doesn't sound like its straining. |
somethings wrong if it is screaming at 3k...that is where most people dont drive below.
"...double clutch on the upshift is nonsense..." Have to admit, I wondered about that "on the upshift" stuff. :) And at 50 I wouldn't even think about 5th.....not even 4th normally, as the car gets too quiet... :D Oh, wait, I have a 915....I do have a 3.2, however, but it never screams; does make some serious kind of growl/happy noise, though....
Change up when the engine starts to sound a little "angry". 3500-4000 minimum.
Very good. I think "angry" describes it well; reminds me of a few neighbors, lol, even though I wasn't even speeding; stock exhaust and all, but stuff happens.............
Shifting Learn to shift like this http://www.rudtnersracing.com/Videos/WatkinsGlen05.wmv No double clutch on upshift, nor on downshift.. Just rev matching... BTW it is a G50 in the 935 we built ;) at one point in the video the cars pass through a ripple in the space/time continuum. and there is a missed shift also.. |
[QUOTE=TimT;5907887]+
No double clutch on upshift, nor on downshift.. Just rev matching... QUOTE] What is the technique for rev matching while downshifting, without double clutching? Are you increasing and matching the engine rpm without speeding up the transmission input shaft? Doesn't that leave clutch friction to speed up the transmission? |
I prefer to lurk on threads like this, but shifting is one of my favorite pastimes so I guess that I'll weigh-in...
1) The 3.2 really starts kicking-in at about 5000 rpm. My car has a Steve Wong chip and seems to want to be revved to about 7000. However, first gear on the G50 is kind of a stump-puller and I tend to get out of it early to get on with things. Of course, around town you probably ought to stay out of that part of the rev range, CMXI's excellent advice notwithstanding... 2) There is a matter of semantics when dealing with terms like "in" and "out" with the clutch. When the pedal is "in" the clutch is disengaged, or "out." When the pedal is "out" the clutch is engaged, or "in." 3) The better you match revs, the less wear on your clutch, and the less you will upset the balance of the car -- the "friction circle" as they call it at Skip Barber. When upshifting you should be feeding in a little throttle as you engage the clutch so that the speed of the engine and the transmission are compatible for a smooth engagement. If you wait for the clutch pedal to fully release, you are using clutch slip (and wear) to match the engine and transmission revs and will experience driveline "snatch" as you describe. 4) The same is true about rev-matching on downshifts, only even more critical to traction and overall balance. This is where proper heel-and-toe technique can make a huge difference when braking and downshifting. I've been spoiled by driving late-model BMW's for nearly 20 years, which have perfect brake/throttle alignment for this. I wound up spending a silly amount of money to install a Smart Racing Products foot-rest and a Rennline adjustable throttle pedal to achieve heel-and-toe nirvana in my Carrera. Three-time Thunderhill 25 winner Rich Walton of Jerry Woods Enterprises has told me that the late 3.2's have a plastic throttle pedal that was apparently designed for the 60 Minutes "Unintended Acceleration" scare and it's just too long a reach to properly heel-and-toe these cars. 5) I always, always, always double-clutch when downshifting. Your transmission and clutch will thank you. Even with the strong syncros of the Getrag gearbox, engagement will always be smoother -- even downshifting from second-to-first on the fly is a piece of cake. It's not necessary to double-clutch when upshifting, but a slight pause crossing neutral will result in better gear engagement. All of these techniques can become second-nature and will take less than a second to execute. Thank you for your interest in one of the great pleasures of driving! |
Shifting is one of the places where you will find really good drivers abusing there equipment, especially when they are operating under the excitement of "going fast".
Tips to improve the shifting portion of your driving:
So what I've taken so far:
1) The consensus seems to be to add gas AS you're easing out (engaging) the clutch and NOT wait until it is fully engaged before adding gas 2) Rev-matching on upshifts - when you add gas AS you're easing out the clutch, you're kind of doing this. Get the rpms to around 2000 before letting the clutch "grab" 3) Rev-matching on downshifts - similar.. basically the same technique? Apply gas AS you're easing out the clutch but get the RPMs even higher than 2000 before letting the clutch "grab" Heel-to-toe on my 3.2 does seem harder given the reach, especially since I put sandpaper on all 3 pedals to help with the grip. I won't be doing this anytime soon: YouTube - Race Car Driver & His Footwork 4) Always double-clutch when downshifting ..feel free to let me know if I'm missing something |
I wonder if folk maybe over thinking the gear change, especially for a street car. |
JR |
If you heel and toe well you can release the clutch like a switch and the cars balance will not be disrupted in any way. Even on a 4th to 2nd shift from 110 to 40. Obviously I don't subscribe to the view that you should downshift one gear at a time. |
first vid
Kelly in his C6 bodied 914 at IMR on Vimeo listen around the :57 mark, you can hear the engine rev match, then clutch in - shift - clutch out is executed in the shortest possible time. second vid Poor downshift = a spin at IMR on Vimeo you can hear the rev match, but timing is off, on releasing the clutch a small amount of traction was consumed as the engine and trans had to match and round we went! |
There is way too much thought being put into this!!
Hands down the G-50 is one of the most straight forward (older) Porsche gearboxes. There are really only three rules: 1. Be smooth 2. No slipping the clutch (unless you are starting in first gear from a stop) 3. Be smooth If you simply concentrate on working any and all jerkyness out of your driving habits WITHOUT SLIPPING THE CLUTCH, then the proper technique will become evident. You will essentially teach yourself. have someone else drive it, or ride with you if you are not sure about the basics. It's hard to describe in the interwebs. Here is a video of me learning the local track (HPT). The car is highly modified, but it still has a stock G50, stock sifter, and stock clutch. I don't do any double clutching in this car. My previous 911 (an SC) did require some extra love to row through the gears. <iframe title="YouTube video player" width="480" height="390" src="http://www.youtube.com/embed/UU0zpSSItXg" frameborder="0" allowfullscreen></iframe> |
Double clutching, rev-matching, heal-n-toe when street driving, totally unnecessary. Its built to funktion as a normal car! Track driving is another thing, but it's not necessary even then...
When to change gear, well it depends. When driving around the neighbors and in the city its fine to change at 3-3.500 and cruise av 2000. But when you want to it's totally OK to change gear at redline, its built for that too! Then there is people that don't dare to rev the car above 4000, and I pity them, they are missing 90% of the cars!! |
I find these "how to shift" threads entertaining, because you only find them on American Internet forums :) |
Here's a video demonstrating heel-toe. The point of heel toe is to match the revs on downshift. This actually takes the synchro's completely out of the picture if you do it perfectly. Nobody does it perfectly - it isn't necessary since we have synchros. Closer is better.
I do this all the time. I've done it for 25 years. It's how I drive. I've never worn out a clutch and I've never had a problem with a 915 transaxle. The factory gas pedal sucks. It's located too far below the level of the brake pedal. You can buy one of those fancy aluminum pedals to correct this. I did. I love it. The factory was, as usual, more pragmatic and cheaper. They just bolt another stock pedal on top of the existing stock pedal. This double thickness is enough to correct the situation. I have no idea why they didn't get it right to start with. You'd think at some point in the 30 year run of the vehicle somebody would have suggested this as a potential area for improvement. Who knows... H |
To the OP, the timing of disengaging the clutch and applying throttle are no different than any other manual trans. ie- applying gas too soon in relation to releasing the clutch will result in slipping the clutch. So, don't over think this. Just drive and focus on shifting smoothly.
There is nothing that will wear out or get damaged in your trans by redlining first gear, provided you remember to let go of the throttle at the proper time and move it up a gear. I'd not worry about double-clutching if you're not sure on when to apply throttle or let out the clutch-work on that timing first in moderate conditions before you get too crazy. |
Yeah. And the thread should be retitled, "Proper way to shift a G50, Carrera 3.2"..... ;) I like your response, Mr. Hughes... :)
Technically, there is no advantage to matching the revs without double-clutching. True double-clutching includes a throttle blip while the transmission is in neutral, which spins the intermediate shaft up to meet the output shaft's rpm, thereby reducing the load on the syncros. Simply revving the motor while pressing in the clutch will only move the flywheel faster and reduce the mismatch between the pressure plate and the flywheel, which is not verysignificant, and those are two surfaces designed to rub each other. The key to syncro preservation is the rpm of the intermediate shaft within the tranny, and that can only be controlled with the engine when the clutch is engaged, and the tranny is in neutral.
(and the 63 Chevy pickup with 3 on the tree, the 76 Corrola 2 door, the 76 Chevy crewcab with the 454 and 4 speed w-unsynchronized granny low, and even the ancient Zellerbach Paper box-truck with 5 on the tree (I was the only person to ever find 3rd in it...), and every other manual trans vehicle I've driven since I was 17.) Correctly matching revs saves the life of the transmission no matter what kind of stick you are driving and adds to the joy of driving correctly and neatly. (and it doesn't add to the effort of driving anymore then not scuffing your feet doesn't add to the effort of walking (while saving your shoes)) As far as non US forums not discussing shifting... Part of that is yes, you can find some discussion but to a larger degree it is because almost everyone there can drive a stick. You can't rent a stick from ANY major chain in the US because the vast majority of American drivers can only drive an automatic. Look on a European rental car site and the base model car has a stick. Then as an example go on the US ebay site and try to find a Volvo with a stick. There are 300 Volvo's listed right now... 24 are manual transmission... subtract 2 commercial trucks and 11 cars from the 50s, 60s, and early 70s... You are left with 11 Volvo sticks for sale with most of them in the east and only one in California. So I think that maybe people in the US should discuss how to drive a stick and might have a tendency to need to learn about it. (Why are so many of the sticks in the northeast? Maybe snow forces people to really have to drive the whole car?) (My more radical opinions include: - The assertion that driving an automatic helps develop a mindset similar to aiming your couch down the road. - That unless you can demonstrate a physical disability, that driving tests should be required to be taken in a car with a manual trans. (Drive the whole car don't just aim the thing!) - That a car is a kinetic energy weapon and unless you treat it with seriousness like a loaded gun it cannot be safe. - Driving a car is an art form and that a lot of joy can be extracted from doing little unnoticeable things well... such as shifting.) |
I think that's the essence of what he was trying to say.
The intermediate shaft has gears meshed with the output shaft > differential; so rotational speed is fixed via various gears meshing with output shaft speed and thus rotates with the drive wheels. It is the rotational speed of the input shaft that must be controlled with the throttle with the clutch disengaged to smoothly mesh with the selected gear to downshift. Some gearboxes shift so smoothly and effortlessly when new/nearly new that some owners feel double-clutching is no longer necessary. Nevertheless, they are a wear item. It just so happens the synchros on a 901/915 are more short-lived compared to more "modern" synchro designs. Owners who feel a throttle blip is all that's necessary will eventually understand the necessity of double-clutching and a well-padded bank account. In many cases, they'll sell the car before it gets to a critical point. Many of those 2nd/3rd/4th owners are on this forum. Sherwood |
So why does blipping do anything when you have released the pressure plate and the input shaft from the engine?? Because you haven't really released it... That whole assembly isn't just coasting in there. When your clutch is released there are only a few thousandths of clearance in there. Air is a fluid and does have viscosity. Think Tesla turbine. The limit of blipping is that the efficiency of transmitted rotation to the free spinning disk drops like a rock as their rotation rates gets closer. That is why over blipping works pretty good and you'll see that lots of people get in that habit. It really shows when you have someone comfortable with the technique take their first crack at shifting a crash box. If you have a driver that is reasonably good at just blipping their downshifts and they don't hurry their upshifts, I would expect their clutch to last 200k+ miles and their transmission to last at least 2 to 4 times that long. Remember that the syncros are simply a metal cone clutch so if you limit the speed differential and the force they are engaged at, it will reduce the wear accordingly. ------ Another detail: I suspect when you are discussing double clutching you are only meaning on downshifts. If you have a car with a syncro-less gearbox then you have to double clutch upshifts too and it is a lot slower. (Yes lots of race boxes with no syncros don't require a double clutch on the upshift (or any clutch on the upshift) but they have lifespans measured in hours when used like that.) |
With the clutch disengaged, one can rev the engine until the cows come home, but there is NO effect on the input shaft or on any internal part of the gearbox. If you blip the throttle and you think it shifts better, that's independent of what's happening between the engine and the disconnected power path to/through the gearbox. During normal shifting and/or with the clutch pedal depressed, the synchromesh assemblies perform the duty of matching the rotational speed of gear shafts. Hurray when they work as designed, and if they work as designed 20 years later, that's great, but YMMV depending on how the POs used/abused the synchros. Downshifting requires the input shaft to speed up to bring the relative rotational speeds of the drive and driven gear shafts closer together (greater speed differential). This action must be performed by the synchros and/or assisted by double-clutching. During upshifts, engine and input shaft speeds gradually decrease relative to increased output shaft and rear wheel speed (less speed differential). This action allows the parts to more easily match rotational speed without further driver intervention. However, if one were to totally isolate the input shaft (clutch depressed, gearbox in neutral), this would result in an input shaft speed of 0 rpm and require the synchro to work harder to match shaft speeds while selecting a higher gear ratio (less torque, more speed). Manual gearboxes for race cars typically use straight cut gears and are easier to mesh w/o a synchromesh assembly. Road car transmissions typically use helical cut gears for greater tooth contact and are thus quieter but less easy to manually mesh, thus the need for a synchro. unit for each forward gear. I hope this doesn't confuse too much. Sherwood |
I'm left wondering how much you know about the inner workings of manual transmissions. (As to quantity that I know: The first time I was asked by someone on another race team to rebuild and modify a transmission was in 1984. I have done a few... If you want to learn about transmissions I recommend opening a BW T40 or T50. You can completely disassemble one with nothing but a socket set and a heavy duty snapring plier.) The ease of shifting a gear box isn't effected in the slightest bit by the difference in straight cut or helical cut gears because there hasn't been an automotive transmission in about 50 years that allows ANY of the gear faces to disengage in ANY fashion. The last box I'm aware of with a disengaging gear gearshift was a 3 speed box used in heavy duty Chevy and GMC pickups up to 1963. (Kind of odd box where the 1st/Reverse gate was actuated by sliding a floating gear around a helical splined center that was about 3" in diameter. I believe the twist of the splines was to cushion the gear contact when engaging by knocking back the sliding gear if there was relative movement.) Modern automotive transmissions are all of constant mesh design. No portion of any gear face disengages unless the trans is disassembled. The only part that engages or disengages in any fashion is the slider over the splines set in the sides of the gear. Alternatively race transmissions sometimes use what is called a dog drive instead of splines. This as the advantage that once enough speed matching has taken place to allow any sort of engagement the taper of the dog teeth will suck the slider into full engagement where it will stay until the torque is released. Porsche 901-915 transmissions use what is commonly called a dog drive but it is really more of a really short spline. The reason that race transmissions use straight cut gears is simple and it has nothing to do with shifting. It is simply because helical gears create a side load when force is passed through them. In other words: one gear tries to slide up its shaft while the opposing gear is forced down. At high force levels it is trying to tear the transmission apart. That is the only reason they are used. Period. (Ok, maybe the ease of designing/building one off or limited run straight cut gears is an added bonus...) --- Back to the point which was blipping without double clutching... - Try a 2nd to 1st downshift at higher rpms while holding the shift knob with only the tips of 3 fingers. Feel how much force is needed to press past the syncro engagement. - Now try it exactly the same with a good aggressive throttle blip. You can clearly feel the reduced effort as you press against the syncros. It may not make sense to you but the effect is very real. This is a much more obvious difference if you are trying this on a trans with a Borg Warner type cone syncro as any speed differential keeps the syncro blocking the slider's engagement. Thus the difference in force levels you can feel are much higher. (The 915 and 901 syncros are more like the self energizing action of a standard drum brake and synchronization is more a matter of giving them enough time to do their job. ) To understand why blipping does effect the input shaft and counter shaft you really have to read up on Tesla turbines. The effect of the boundary layer friction is very real even if it counter intuitive. This effect is much stronger if you barely disengage the clutch which is how most people drive by reflex. If you push the pedal to the floor there is much less effect for the obvious reason that the wider gap massively reduces the boundary effect. --- The real effect we are left with is that a somewhat simple discussion has become WAY to confusing for Porsche 911 as he starts playing with the most educational car that is commonly available: The 89 and earlier aircooled 911. These cars will talk to you in ever increasing detail. If you actively concentrate on learning every time you get into one of these cars you will still have Aha! moments 5 years later as little details are revealed. |
| All times are GMT -8. The time now is 08:57 PM. |
