911 SC Headlight Switch
Any tips for removing the dash headlight switch. I have tried using circlip pliers on the small holes, but no luck. Apparently someone over-tightened the retaining piece.
Josh
Old 03-18-2011, 08:27 PM
Oh Haha's Avatar
Unless the PO glued the retaining disc into the dash it needs to be rotated to remove the switch. Maybe try using needle nose pliers to get some extra leverage. (Not to be a smarta$$ but righty-tighty, left-loosey.)
They are widely available so if you fark it up, a new or used one can be had.
Pacific Blue
Wayne
Old 03-19-2011, 04:09 AM
arbita1's Avatar
I believe I used the tip of an awl in one of the small holes on the plastic disc. Make sure you hold the body of the switch from behind with your hand so it doesn't want to rotate.
Matt.
83 911SC
85.5 944 NA - Sold
Old 03-19-2011, 05:12 AM
Flat Six
Flat Six's Avatar
Josh
Josh, I found that circlip pliers had too much flex in the tips to get much purchase on the threaded retainer; for me, bent-tip needle nose pliers work great. Much more robust and allows you to reef on the retainer a little more (works on the mirror switch in the door cap, too).
HTH
Dale
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 03-19-2011, 07:38 AM
Bent tip pliers worked great...Thanks!!! Look for my next post for next issue.
Old 03-19-2011, 11:41 AM
