911 SC Headlight Switch
Any tips for removing the dash headlight switch. I have tried using circlip pliers on the small holes, but no luck. Apparently someone over-tightened the retaining piece.
Thanks Josh |
Unless the PO glued the retaining disc into the dash it needs to be rotated to remove the switch. Maybe try using needle nose pliers to get some extra leverage. (Not to be a smarta$$ but righty-tighty, left-loosey.)
They are widely available so if you fark it up, a new or used one can be had.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
I believe I used the tip of an awl in one of the small holes on the plastic disc. Make sure you hold the body of the switch from behind with your hand so it doesn't want to rotate.
Matt. 83 911SC 85.5 944 NA - Sold |
Flat Six
HTH Dale
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Bent tip pliers worked great...Thanks!!! Look for my next post for next issue.
