Got spark at coil aqnd plugs.
Removed center tube on fuel distributor, fuel comes from the dist??!! when I operate the airflow switch. Dumped gas in the pop-off valve, no start. Put starter fluid in Pop-off, and throttle body, no start or fart. When push air flow switch, hear buzzing under hood (engine). Next pull plugs and measure Voltage at fuel pump? GOT ME BAFFELED |
timing?
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
911SC, 1983 will not start
Checked static timing with rotor at 1, the timing mark aligns.
What bugs me is the the starter spray does not produce any response, AND I have (think) ignition! |
