Obsessed
sobamaflyer's Avatar
Indicators don't work with Headlights on?
During the day with no lights on my turn-signals work fine. Might anyone easily suggest why they don't work if I have parking and/or headlights turned on?
Thank you, Travis
'73 Mercedes 450 SL
'75 911 Targa (long gone, sniff..)
http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog
"Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!"
Old 03-21-2011, 11:22 AM
Diss Member
Quicksilver's Avatar
The headlights are routed through the indicator switch because that is the high/low switch also. Check that the wire from the stalk is firmly plugged in under the dash. Next I would try cleaning the switch which does require pulling the wheel.
A VERY highly recommended upgrade is the headlight relay mod. This keeps the high load of the headlights from being pulled through the $100+ headlight switch and the $100+ turn indicator swit.ch
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-21-2011, 11:49 AM
