-   -   How in the heck - radio install question (http://forums.pelicanparts.com/porsche-911-technical-forum/597985-how-heck-radio-install-question.html)
313green 03-20-2011 10:56 AM
I purchased an original blaupunkt, but how do I remove the old radio? The hvac unit is in the way. Do i remove that first? thanks ... and, as always, us newbies really appreciate the advice and help. (second picture is looking up at the bottom of the hvac unit).
http://forums.pelicanparts.com/uploa...1300643662.jpg
http://forums.pelicanparts.com/uploa...1300643697.jpg
Bob Kontak 03-20-2011 12:50 PM
Try this site. Says the dash piece slides to the right after you push the radio in far enough to clear the stems. Then the radio pulls out from the front.
May be fastened from behind as well meaning the AC stuff needs to be pulled.
http://forums.pelicanparts.com/porsche-911-technical-forum/530382-help-removing-radio-early-911-a.html
RSTarga 03-20-2011 02:46 PM
Take knobs and nuts off then radio cover panel "should" be able to be lifted out. Press down on top and once top is out you can lift out. Most probably radio is braced in back so you'll have to remove A/C.
