I bet there are more photos than those 2 Green! Looks like a SC or Carrera tub.
- Tectyl waxed tranny - 1962 356 Ruby Red acrylic urethane on engine shroud etc - 6 probe EGT & 6 CHT monitoring - angled 6.5 woofer up to driver - elaborate perforated steel engine compartment panel loaded with all kinds of crap - 2 micron Racor fuel filter/water separator [general use is 10 micron] - ungraded stock multi-piece air deflector to one piece plastic Carrera deflector -added ground strap from under starter mount bolt to front tranny to chassis bolt - large diameter 5# carb gauge with surge suppressor - two fuel regulators for carbs. One by-pass set to 10#, one dead head @ 3.5# - loctite Graphite-50 for spark plugs & loctite nickel anti-seize for exhaust - many gold plated terminals - momentary on switch starter jump in engine compartment - marine MSD box - Blue Sea Systems 8 CB panel up front next to battery - two 75 amp relays instead of 25/30 amp cubes for headlights - blended gold metal-flake brown C-2 electric spoiler to match rest of stock color [maybe 4 tries] that's all i can think of that's "out of the ordinary". Non of this stands out and is only noticeable if you know what you're looking at. Car is very low key but it's a madman's dream ps: 930 brakes, E-cams, Wevo x 6, etc etc is not out of the ordinary |
everything. Well, almost everything.
http://forums.pelicanparts.com/uploa...1300689425.jpghttp://forums.pelicanparts.com/uploa...1300689456.jpg http://forums.pelicanparts.com/uploa...1300690824.jpg http://forums.pelicanparts.com/uploa...1300690716.jpg http://forums.pelicanparts.com/uploa...1300689837.jpg |
http://forums.pelicanparts.com/uploa...1198046606.jpg http://forums.pelicanparts.com/uploa...1198549934.jpg http://forums.pelicanparts.com/uploa...1198550015.jpg http://forums.pelicanparts.com/uploa...1198550225.jpg |
I'm kinda new at this so my list is short. I've replaced my turn signal switch, fixed the front fog lights and recently did routine maintenance - valves, oil, plugs, fuel filter, etc.
I'll follow Green 912's lead with another '77 911S donor:
http://forums.pelicanparts.com/uploa...1204592170.jpg http://forums.pelicanparts.com/uploa...1204592089.jpg http://forums.pelicanparts.com/uploa...1224943206.jpg http://shn.pca.org/images/BP100814gb.jpg http://forums.pelicanparts.com/uploa...1299248302.jpg Yes there was some cutting and pasting involved! Everything was done by myself and a few friends. The only labor I wrote a check for was my buddy spraying the final coat of paint/clear! |
Project #30 on my list Right side Parts http://forums.pelicanparts.com/uploa...1300711606.jpg Cutting http://forums.pelicanparts.com/uploa...1300711641.jpg Welding http://forums.pelicanparts.com/uploa...1300711709.jpg Primed and POR-15 http://forums.pelicanparts.com/uploa...1300711754.jpg Passenger side Parts http://forums.pelicanparts.com/uploa...1300711793.jpg Rust http://forums.pelicanparts.com/uploa...1300711826.jpg Fitting in place http://forums.pelicanparts.com/uploa...1300711867.jpg Welded in http://forums.pelicanparts.com/uploa...1300711937.jpg |
Currently I am mostly without a working 911 ...
http://www.martinandsonja.f2s.com/91..._out_small.jpg oh, yeah - I rebuilt this from the ground up http://www.martinandsonja.f2s.com/50.../BSLKasino.jpg |
| All times are GMT -8. The time now is 10:17 AM. |
