What have YOU fixed on your ride? No check book mechanics.....
I started listing my mods in another thread.....then I started on what I have fixed.....
FIXES Blew 2nd after my 3.6 install. WEVO mods followed. Rebuilt 915 with help 3.6 r&r sealed everything standard maintenance, oil, valves, brakes trouble shot dead DME....ended up being bad switched power input installed Recaros, made custom sliders installed roll bar fabbed tow hitch from scratch installed dual oil coolers, fabbed lines and installed finned lines from Chuck Moreland replaced incandescent bulbs with LEDs steering bushing interior door switches and fixtures fixed washer pumper, lost headlight washer AC delete Head light flasher/stalk New CVs and axles New spring plates and bushings Welded/repair rear sway bar mounts Shifter bushings Removed center console MODS TRE glass front bumper, fenders, hood, 73 RS back date duck tail 7 and 8 Fuchs Carrera sway bars, 22/29 t-bars Sport engine and tranny mounts dual oil coolers 3.6 with injection, early Timmins kit......LOTS OF CHANGES Wevo shifter and trans upgrades RS carpets, Leather Recaros, dropped driver ride height 3 inches Konis R tail lights, LED back ups H4s, Cibie H1s Light relays 993 gauges Roll bar Wiper relocation/single wiper AC delete, heat backdate Euro ride height Corner balance 993 HEs, 3 inch single outlet No Bad Days performance chip Probably more....... Oh yeah, Ash canned crappy VDO clock, replaced with head Temp and Volt Meter Upgraded tunes with IPOD input dual marine blowers for heat ($20 bucks each, eh) ash canned crappy paper heater tubing with aircraft SCAT Optima Yellow Top, Marine fittings with kwik disconnects Permanent Battery Tender pigtail Elephant Racing finned oil lines with air assisted blow down de chromed, de badged 930 steering wheel |
see my sig
All the easy stuff (sorta):
Repaired odo (today; He** yes I'm proud), replaced body parts (rocker, bumper pad, installed H4s, swapped to Euro rear lenses), added a hood strut, oil, valves, idle, swapped out to sport seats (OMG what a diff.!!!) and OEM 930S steering wheel (fantastic), swapped out chin spoiler and turn sig./hi-low switch, went to newer, nicer lug nuts (+ a second lock on each wheel), adjusted Targa top several times, fixed rear seat straps, adjusted ride height, added front coco mats, slapped a 40 year old hood emblem on (love that), mirror bras (OEM with Porsche "shield"), ripped out most AC krapp, and checked the air in the tires ;). Oh, and made friends along the way, like my buddy JB.... :D Bought some shirts, too............I know, easy sh*(, but all good. I'm no wrench. :cool: Out with the old: (Yes the new is working perfectly. Funny how that "Peanuts" comic is right there; not a staged shot, I swear!)... http://forums.pelicanparts.com/uploa...1300673808.jpg |
Shifter bushings and made a spring loaded gate.
pulled ign. switch and fixed it. fixed door switches (lights) dropped motor and trans. fix oil leaks and new (to me) oil cooler. Rear susp. bushings. Rebuilt all calipers. made a new window (spring) pivot pin Repack and replace CV boots (all) replaced odometer gear tune-up fixed head light switch (on the column) I'll quit here but there's lots more little stuff |
A few of my projects over the years
1. Replaced engine blower fan and squirrel cage for heat 2. Removed and replaced 915 Transmission with fresh rebuild 3. Engine compartment noise deflector installed 4. Heat exchangers, both heater hoses to body 5. Replaced valve cover gaskets, all new hardware 6. Repair backup light switch 7. Replaced both half shafts 8. Replaced clutch cable 9. Clutch helper spring 10. Sway bar bushings 11. Removed engine, cleaned and de-greased engine mounted oil cooler 12. Engine compartment hood struts 13. Installed third eye brake light 14. Oil and filter, strainer kit 15. Ignition wires, rotor , distributor cap, spark plugs 16. Front hood struts 17. Installed Carrera chain tensioners 18. Replaced brake calipers, rotors, all brake lines. 19. Installed H5’s 20. Installed Dansk sport muffler 21. Oil breather gasket 22. Oil pressure gasket 23. Oil pressure sender unit 24. Momo steering wheel 25. Aluminum floor boards 26. Removed and repainted fuel tank 27. Replaced both front fenders ( paint done by a Pro) 28. Replaced front bumper smile 29. Installed front spoiler, installed Duck tail 30. Cut out and welded in new front bumper shock supports 31. Removed entire A/C unit 32. Installed Carrera oil cooler Thats all I can remember right now. I still have a room full of new parts to be installed. |
brake rotors and pads, rear shocks, oil and filter countless times, modified airbox cover! sounds faster! installed strut tower brace, installed new front smile on front valence. pulled injectors to be rebuilt and flow tested, replaced. installed new fan belt. put in steve wong chip, clipped the brown wire (actually noticed a difference on that. cool) replaced cracked fuel line on top of engine! that was a ***** with the engine in the car! switched out stock seats for sport seats. replaced burnt out front wheel bearing and cracked hub.
I left plenty of other stuff to the mechanics because I know my limitations |
OMG, only 32?
I stopped counting, Recently I fixed my scratchy steering wheel. I replaced the "wiper switch" with Zimm's repro and found it still made the annoying scratching noise. I noticed the scratching only occurred at the top 1/4 section of the steering wheel, consistently. I removed the steering wheel. Observed the switch and it seemed fine but then I ran my finger along the steering wheel's copper contact. I took some emery cloth and smoothed out the 1/4 copper contact section and even the edges. Well that did the trick. My deduction: since the steering wheel sits most of time on the 1/4 section of the copper contact,, road vibration would cause the switch to rub up and down on the copper contact inadvertently cause scoring and scuffs on the contact which results in the "scratching noise". Sorry for the hi-jack, just wanted to share. Jim |
This is what I haven't done, replaced glass, removed doors, removed fuel tank, rebuilt front suspension, rebuilt rear suspension, removed dash, replaced brake booster.
It's a smaller list!! |
Haven't had much to do yet.
Replaced stock seats with corbeau targas and made my sliders. Replaced motor mounts And since I just ordered my rs door panels ill be putting those in when they get here :) |
Quote: "It's a smaller list!!" LOL....
High light any mod or repair that is out of the ordinary.....
I really like those guys that can straighten out and cut and paste body parts, that's art. Any one done that?
Ok, I'll bite:
Bilstein HD Insert/Boge Strut slop housing fix with 8 gauge copper wire Oil Level Sender Unit Repair without replacement Starter Refresh Service without replacement Heat Exchanger Inlet and SS tube re-rounded on my driveway safety post and a sledge. ( it was squeeshed somehow ) |
Yeah, list your rust repairs.....
They rust?
they bend!
they leak?
they get into accidents before you buy them?
http://forums.pelicanparts.com/uploa...1300678270.jpg
Only one line item. From^......To v http://forums.pelicanparts.com/uploa...1300678287.jpg |
| All times are GMT -8. The time now is 07:43 AM. |
