kiwior's Avatar
fan housing
Is a fan housing from a 3.0 interchangeable with a 3.2????
Mark & Trish
1995 993 Cab
1986 911
Old 02-10-2002, 05:21 PM
stormcrow's Avatar
Hope this info helps.
Fan
911 1980 - 1989 930 106 012 00
911 T 1976 - 1989 930 106 012 00
Fan Housing
911 1984 - 1989 930 106 012 07
911 T 1986 - 1989 930 106 006 06
Apparently the fan is the same size because both numbers are the same for different years. With regard to the housing, the numbers are different for the 911 and the 911T.
Old 02-10-2002, 06:57 PM
kiwior's Avatar
Thanks Steve.
Mark & Trish
1995 993 Cab
1986 911
Old 02-11-2002, 03:36 PM
KTL KTL is online now
Schleprock
KTL's Avatar
All it takes is a little "coaxing" with the four-pounder. Got the MOXIE?
Still got that bumper if you want it.
Kevin L
'86 Carrera "Larry"
Old 02-12-2002, 10:48 AM
304065's Avatar
Porsche Crest Fan Housing
Kiwior,
I am not absolutely certain that the 245mm later SC housing and the late carrera housing are the same. The part number is the same, but the revision number is different. I have an alternator that fits an 88 Carrera and it didn't fit properly with the early 0R housing, I had to grind some metal off the back to get the air guide and nuts on. My 88 Carrera has a 4R casting number, so while it's the same part number, the casting was changed along the way. Would be interested to know your experience- if you are using a later alternator with the SC shroud.
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=57565&highlight=fan+shroud
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-13-2002, 04:31 PM
