blowing oil 82 911 sc
I recently drove my 1982 911 SC Targa 250 miles to a car show without any problems. The next morning as we went to leave for home, I fired her up, let her warm up for about 10 min and headed down the road. Never made it past 3rd gear when I noticed heavy smoke from the rear. I pulled over and all my oil had blown out. Not sure where it was coming from, cleaned and checked all hoses, areas around the front, rear and head gaskets were clean and dry. Oil seem to be comming from the passenger side somewhere around the oil tank. Cleaned all the oil off and added 6 qts. Started her up with now problems, misses or noises. I let her run for about 10 min without any leaks or smoke. Headed down the road and got about 200 yards and blew all the oil out again.. Still couldn't see where it was comming from. Any help would be great.
"S" hose between tank and cooler?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Somatic Negative Optimist
Losing oil that fast should be easy to trace.
Stay in your driveway, refill, start engine, look underneath and see where it pours out. Someone may have to rev it up for you to increase oil pressure. May be the S hose or a blown oil cooler? |
All the oil?
What does the dipstick show? |
Found it, Now what
Found that the crankcase to chain cover oil line was blown..... Anyone know what would cause it? Was not old and brittle, just blown....
Senior Advisor
Cause? cause it failed. need a new one. Most likely one of the brazed joints failed due to harmonic vibration fatigue. my guess. Good catch. Pelican has these lines in stock.
08 Cayenne Turbo |
Oil Oil well....
Thanks for your help.... love this site.....
James, If it was this oil line, wouldn't there be oil all over the engine compartment?
Kipp 1987 Black 911 3.2 Carrera Coupe 1999 Green Mazda MX5 (SOLD) |
Fleabit peanut monkey
Senior Advisor
MH911, I thought that's what he said? chain case oil line (tensioner). Im sure oil is everywhere like being stabbed, a little blood looks like a lot!!
08 Cayenne Turbo |
Now also get the little rubber cushioned supports for the new cam oil lines. The vibration probably let loose the end-brazed connections.
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
