uncommon oil leaks 911 1982 3.0 SC
Hello,
I have spent quite some time replacing all the gaskets, seals, rubbers etc. as described in Wayne Dempsey's handbook. Unfortunately still leaks (even when the engine is not running). It seems to drip down somewhere from the cylinderheads (not the return tubes, I've replaced them and they're dry).
Could it be the cylinderhead bolts that need to be tightened? Or a gasket to be replaced between engine and cylinderheads?
Bas
Old 09-17-2016, 12:34 PM
schoward's Avatar
I think they call those base gaskets or base seals. In my case, retorque of head bolts/studs didn't help with a weeper and I am told that could even make it worse.
Scott
1981 911SC Targa - Platinum Metallic
Old 09-17-2016, 02:07 PM
pors1968's Avatar
I would check for broken head stud .
Old 09-17-2016, 03:56 PM
Could be leaking from the top. Oil pressure light switch, breather cover, breather hose.
I had a breather hose leaking all over the top of an engine once. Don't get the woven type get solid rubber.
Old 09-19-2016, 07:28 AM
Actually, that is common.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-19-2016, 08:32 AM
