Bad Alternator/Optima advice...
I had the 911 out today for a long extended drive (limited driving during the winter months) and put her back on the Xtreme tender at the end of the day. The tender indicated 25% initially and though I didn't break out the multimeter to check with the car running, I'm assuming the worst. I'll diagnose and make a plan (rebuild, replace, etc.) later, but I've got so many projects going on, spring has sprung, and I just don't want to tackle it for a few months. Is there any harm in continuing to drive her (shorter periods but alway up to temp), but not down that low (say down to 75%), and then always going on the tender when garaged?
Senior Advisor
Is the alt light on?
No it wasn't James...I've always assumed the alt light was a go/no go for the alt/fan turning. Is it related to the alt's output too? I haven't even done basic research on threads I've read over the years, but will later. I'll get a multimeter reading from the battery with the car running tomorrow. Thanks!
RETIRED
The battery may be salvageable.....
Charge it fully, should read 12.5-12.8 at rest. Start the engine, 13.0-13.5 at idle 13.5-14.0 at 2500 rpms Anything under 13 while running your alt is toast.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I'm sure the battery's fine...took no time to return to 100% (via tender)...I'll probably get those readings later on today, and proceed accordingly. Assuming the alt IS toast...would occasionally driving it for several months regularly going from 100>75>100% be risking the Optima? Obviously, that's not ideal, but I JUST don't want her "down completely" right now if I don't have too...thanks!
Senior Advisor
Read the voltage at the battery with the engine running around 1000 rpm and see what you get. A new battery, no matter what brand it is will die if the Alt. is not charging.
08 Cayenne Turbo |
I wouldnt drive with a bad alternator/voltage reg... that is a sure way to kill your battery...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
RETIRED
The light is part of the charging circuit. It could be as simple as replacing it.
. After driving around a bit today, I did some checking...both at idle and 2K rpms, my alt output seems just fine (a bit high, 13.9 at idle...no biggie I assume). Then checked the battery, fully charged...all is well. Hooked up the Xtreme...indicates 75% for a bit then 100%. Thank you all! signed..."the boy who cried wolf" |
I don't know how knowledgeable you are, but are you aware that these alternator-regulators are noted for failing INTERMITTENTLY to the high side, 15+V?
Richard 1989 Venetian Blue Targa |
. Thanks!
RETIRED
13.9 isn't out of line....could be a result of a high idle when cold. When you start getting over 15v you can fry things. Not just the battery.
That's why I always recommend replacing the crappy clocks with a head temp and voltmeter. You really should do a read at 2500 rpms or more and do a few times. Bad VRs can be spiky as mentioned above. BTW, the stoopid LEDs are there to entertain not edumecate. Pretty sparkly thingies are for the mullet-headed MOPAR guys.
Senior Advisor
Ok sounds fine now go out and drive!
08 Cayenne Turbo |
Senior Advisor
Heres a good mod, remove the oil quantity gage and put in a voltmeter from Palo Alto Speedometer. Looks like it belongs there and you can always monitor the charging system. mine runs around 14.3 volts most of the time. You just have to check the oil quantity manually, but you do that anyway, right?
08 Cayenne Turbo |
! I checked their site and will give them a call. Thanks!
I think the dancin' fool, JB has it nailed. I have a factory option volt meter in the center console. It helped me find the VR problem very quickly.
RETIRED
Gee thanks...
![]() BTW, I had my VM/Head Temp gauge made by Westach. I had an over charge stoopid light added for 15v. Comes on at power on, goes dim at idle. Worth the extra 20 bucks at the time.
Senior Advisor
He ment James Brown not Joe Bob!!!! Anyway, same info is always good, and "I feel good"!
08 Cayenne Turbo |
