coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
Another suspension project...
Having completed the 3.6 transplant project and put the car into storage in Finland before the move over in January, my attention turned to planning the next project and giving myself and the car a nice Christmas present
With the additional power I decided it was time to focus on the suspension (again), and after a lot of discussions with Chuck, he is now putting together a top of the range Elephant Racing coilover solution for me.
I will post more as I get pictures and details - more to come
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 12-06-2010, 01:13 AM
Chuck Moreland's Avatar
I think you will have a good Christmas, Pål
Chuck Moreland - elephantracing.com - vonnen.com
Old 12-06-2010, 11:18 PM
yep, im slow in the head
carslutt's Avatar
Send a message via Yahoo to carslutt
wow that looks like an great setup,...... def want some pics of the braces being welded in and any other changes u need to run this stuff.
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something
Old 12-06-2010, 11:46 PM
Less brakes, more gas!
euro911sc's Avatar
Gee thanks Chuck... now I have to clean up the drool off the desk...
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 12-07-2010, 06:13 AM
Send a message via AIM to NoLift911
So where does all the bracing go?
Jeff
Old 12-07-2010, 06:38 AM
French Import
zippy_gg's Avatar
Chuck, will this coilover system replace the torsion bars or will it supplement them?
Can you give an indication of the cost (for an 86 cab)?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 12-07-2010, 06:57 AM
Formerly known as Syzygy
Canada Kev's Avatar
Probably to strengthen the rear shock towers.
Kevin
Old 12-07-2010, 07:23 AM
coolcavaracing.com
Kroggers's Avatar
Thank you Chuck, I think I will as well It is just a shame those sexy components will be hidden away once installed...
I would have posted earlier today and replied to some of the questions, but our two year old managed to chip two bones in his left foot, so I have spent most of the day in A&E followed by a number of other departments and weighting rooms!
Chuck sent me over some additional pictures during the day that I thought I would share with you all - I just can not stop looking at this stuff, I hope it does not take to long to get here...
I will leave it for Chuck to give some technical details on the set-up, but it is based on the Elephant Racing Level 3 configuration.
To answer some of the questions, this set-up will replace the torsion bars completely. As for the cost - have a quick look on the ER site, or Pelican. If you are in Europe, then Chuck has some good partners that can help...
The bracing goes at the top of the rear shock towers to give additional support. Removing the torsion bars and installing coilover struts moves the loads and therefore additional bracing is recommended, as in these picture (from the ER web site).
Old 12-07-2010, 09:41 AM
Pål's pictures show the rear shock mount reinforcement pretty well. The rear shock mounts were not designed to support the loads of coilovers. Specifically the crossmember is poorly attached to the chassis, it is attached with some spot welds and some seam welding depending on year.
The reinforcements strengthen the area and couple the loads into the box sections and chassis.
Old 12-07-2010, 09:30 PM
coolcavaracing.com
Kroggers's Avatar
Chuck, you fancy posting some technical details on the above pictured set-up?
Old 12-07-2010, 10:09 PM
Here is the list of stocking stuffers:
- Von Street rear coilovers, external rebound adjustable, level 3
- Modified bilstein struts with +30mm raised spindle
- Racing adjustable bump steer kit
- Coilover sleeve conversion kit
- Von Street inserts, level 3
- Brake line support kit
- QuickChange Camber plates
- Rear shock tower reinforcement kit
The picture above shows detail on some of the cool bits.
The spindles on the struts have been raised. Pål's car is fairly low and will benefit from the improved suspension travel and geometry of the repositioned spindles.
You can see the racing bump steer kit. With the raised spindles, you have compensate for the height at the tie rod end or else you will have profound bump steer. This kit has the second steering knuckle attached to the strut beneath the tie rod end. This eliminates flex and makes the assembly very strong. Fully adjustable for tie rod end height.
Coilover threade sleeve conversion kits are fit. This is an easy way to fit full coilovers. They are provisoned with main and helper springs.
One problem with coilovers - the hard brake line support has to be removed from the strut. So we fit our brake line support kit. That's the stainless bit you see near the lower spring perch.
Above is nice detail on the QuickChange Camber plates. This lets you adjust camber independantly of caster. You do this by loosening that big hex nut and sliding that center carrier to the desired camber position. A scale is provided with marks for every .1 degree. So you can experiment with different camber settings, and return to your original position if desired.
It's also a good shot of the extended upper spring perch. The perch is much smaller diameter than the spring, and is long enough to position the spring down below the area of chassis interference. This lets you adjust for maximum negative camber, without the spring interfering with the chassis. Without that your camber range gets limited by the coil OD.
Old 12-08-2010, 10:04 PM
Sports Purpose 911 Driver
mjshira's Avatar
I want, I want!
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 12-09-2010, 05:59 PM
coolcavaracing.com
Kroggers's Avatar
Happy Christmas to me
My lovely Christmas gift from Chuck was delivered this morning. Now I just wish the car was not parked in a garage in Finland far away from me at the moment - I so want to get stuck in and install these babies
these things look so good I just want to hang them on the wall as art.
If I have some good luck and can manage the family properly, then I should be able to consider installing these during the spring in preparation for getting a full alignment done once the snow has melted...
I am holding for some recommendations from Chuck on alignment settings that will work best for my car.
I will post back once the installation work starts, with lots of pictures and feedback...
Old 12-15-2010, 10:50 AM
AutoBahned
RWebb's Avatar
you could install them, then hang the car on the wall as art
Old 12-15-2010, 11:44 AM
coolcavaracing.com
Kroggers's Avatar
I think the wall would fall down if I did that
Old 12-15-2010, 11:50 AM
AutoBahned
RWebb's Avatar
then you OBVIOUSLY need a new wall
and.... that means a new garage
Old 12-15-2010, 12:04 PM
Flat Six
Flat Six's Avatar
Originally Posted by Kroggers View Post
I would have posted earlier today and replied to some of the questions, but our two year old managed to chip two bones in his left foot {SNIP}
Practicing his left-foot braking, no doubt!
Dale
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 12-15-2010, 12:51 PM
By using the RSR Adjustable bump Steer kit.... I'm thinking you would no longer need a Turbo Tie Rod... is that correct?
Brent
Christchurch, New Zealand.
Project: 1973 RSR Clone build http://forums.pelicanparts.com/porsche-911-technical-forum/576125-nz-73-rsr-clone-build.html
Old 03-31-2011, 12:10 AM
Max Sluiter
Flieger's Avatar
The bump steer kit is mounted on the Turbo tie rods. I do not know if the kit includes the Turbo tie rods, but either way you still want them.
Old 03-31-2011, 10:05 AM
Thanks, Flieger.
Brent
Old 03-31-2011, 03:21 PM
