ASE Master Tech - 35 yrs
- is the relief setting significant
& if so, WHY? Fram PH2815 early 911 914-6 etc Filter Bypass Relief Valve: No Relief Valve Open (psi): 19-37 psi Anti-Drainback Valve: Yes Smallest Particle Filtered: 18 microns Thread Size: 3/4-16 in. Fram PH8A - suggested interchange Filter Bypass Relief Valve: Yes Relief Valve Open (psi): 12 psi Anti-Drainback Valve: Yes Smallest Particle Filtered: 20 microns Thread Size: 3/4-16 in. PH2842 2.7- 3.2 engine Anti-Drain Valve YES Relief Valve Setting PSI 28 Thread Size: 1-12 .
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
oil filter
Don't use fram filter use wix fram is a crappy filter ...i know
Save your self heartache, get a MAHLE.
+1 mahle
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
+1. +1. Mahle!!!
Member 911 Anonymous
I posted a comparison between wix and mahle, constuction was close but due to wix filter it was too restrictive ( cleans too well, it restricts flow) and caused engine to get hotter faster. stick with mahle.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 02-13-2013 at 10:15 AM.. |
Senior Member
This saving of a few dollars is what you would do if you were driving a 1976 Toyota SR5.
'78 Targa in Minerva Blue |
R&D guy
Location: the border between the states of inebriation & confusion
++1 on Mahle.
Fyi, when doing a tune up & changing filters, I just put in an order for all the items I need to the friendly & helpful folks at Pelican Parts. |
Driver
Regarding using a Fram:
On one hand, when I go to vintage races, I see a lot of those Ferrari guys (the ones with the 7-figure models) with Fram filters. On the other hand, a few years back a guy on a motorcycle board cut up several filters and noted that the Fram's filter media (or perhaps it was the material at its base) was made up of some crappy cardboard-like material that disintegrated after use. That would actually be worse than no filter at all, as now there were particles of stuff floating in the oil supply. Since then, with so many choices on the market, I avoid Fram at all costs. Why reinvent the wheel? Go with the Mahle. The guys who run the shops that service these cars seem to univerally use the Mahle. They see far more Porsche engines than I do.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa Last edited by Noah930; 02-13-2013 at 10:41 AM.. |
Mahle or Mann.
Dustin |
Why such a bad rap for Fram? I drove 3 VW Diesels for a total of 1.25 million miles.
I used exclusivly Fram filters and Castrol GTX 20/50. I never did anything to them other than routine maintenance. Never had a head off, never added any oil between changes, only the 86 with hydraulic lifter wound up with some high blow by at around 400,000 miles and I still have that motor for a different project. However in my SC I do use only Mahle or Mann and Valvolene Racing oil. The cost of a 1.6 VW Diesel engine compared to the Porsche 3.0 is quite different. So for the SC I use the advise offered here. Terry
79 SC Minerva Blue ROW Non Sunroof Crank Window Coupe 3.0 SSIs, Backdated Heat COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires |
original question - why is there a difference in relief valve settings?
i get the product zealot issues, and i'm not asking cuz i am looking for cheap - and i also understand that if you run a filter for a zillion miles (or simply beyond its recommended service life) or just let it sit on a trailer queen for 10 yrs, it might certainly disintegrate internally (anti-drainback feature is irrelevant when the filter is mounted horizontally as on a 911 914-6 oil tank) ????????????????????? .
Sorry Larry,
Did not mean to sound like we were flaming you. As for me, I too was curious why the Wix filterred so well in microns vs Mahle. What I discovered, the Wix filter worked too well where it would restrict the flow and as a result a raise in temps, since I use to have crushed lines it made the higher temps in summer worse. As far as the "relief" settings, I choose Wix because it was close to OEM/Mahle. I am not sure if the relief settings is critical unless it is too tight where it would restrict flow
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I have been told by those who have witnessed all kinds of engine failures, the real answer of why most mass market filters are not ok for the Porsche flat 6 engine. It has to do witht he operating pressure of a 911 which is some what higher than your typical application, Has something to do with how the scavenge pump operates at higher revs.
This is an interesting thread on the topic: Seattle Pelicans help me find an oil filter
Check this comment: Quote:
Location: behind the redwood curtain, (humboldt county) california
Oil pressure dropped to half on track
some time ago, i serviced my car, looking forward to getting it on the track again. I installed a fram filter, (received from PO and put in redline 20-50)
With the car warmed up, things were going well. temps within reason, then i noticed 20-25 psi oil pressure at 5k rpm. so i came in and let the car cool off. Went back out but the pressure was not normal, still low. Nursed the car home, did all of the usual checks, (pressure relief disassemble & clean, mechanical gauge confirmed low oil pressure, so i changed oil and filter and pressure was restored. I decided to have a look at the oil filter - ![]() ![]() ![]() chris |
Many moons ago, I shared this race car with a partner:
![]() On my first lap of my first run session on a cold Laguna morning, I got a face full of oil coming out of T2 (note the air exit on the hood for the front mounted oil cooler). The secondary Fram oil filter mounted in the front trunk had blown apart. I pulled off the track, was towed in, we replaced the oil filter (with a Mann a fellow PCA loaned us), cleaned up the oil on the car and my partner took the car out. Unfortunately, at the top of the corkscrew, an oil line let go on the engine. He then proceeded to dump oil on the line all the way to T10. It took over an hour to clean up the mess. For over a year, we were know as "The Captains of the Exxon Valdez".
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
Reiver
Fram ain't what it use to be, like lots of products....some Ferrari guys use them because back in the day they came with the dual fram filters and they like to see that orange can(s) in a concours.
They prob work ok in low psi systems but I won't put them on anything. Great pics and stories. |
