Decode 915 serial number , pls
Can anyone decode this tranny number for me?
9153811021R Is it a mag or alum case? 7:31 or 8:31 R&P? Thanks |
Mag is sort dull grey aluminum is brighter and more silver.
Looks like you posted a casting number. The serial number is on the very bottom of the trans and, for a 76, should start with 716xxxx or 766xxxx. If your trans is a stock 76 then it is a mag case. (AL cases started in 78). Start with the serial # and re-post that for more accurate info.
edit: check this link for photo of location. http://forums.pelicanparts.com/porsche-911-technical-forum/522417-transmission-number.html |
| All times are GMT -8. The time now is 07:01 AM. |
