Diss Member
Carrera coil alternatives?
Seems that the coil on my car swallowed itself this morning and wondering if there are any usable alternatives to the Bosch coil. I would like to get one now so I can move the car and worry about the correct one next week.
Will an old bug coil work or something like that? (or something else cheap?) What choices are there?
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
No, but the same coil was used in the 944 so it should be redily available.
Bruce |
AC Delco, Borg Warner and Echlin all have a crossover part. Check your local parts houses if you not hung up on the Bosch coil
I just installed a PVL #101-400 (made in Germany) ignition coil. Napa part # ECH-IC74 in my 87 930 and it runs fine. I hope it lasts longer than the Bosch coil.
Thank you, HFR_Racer '87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups. Last edited by HFR_Racer; 04-21-2011 at 03:56 AM.. |
