Weekend Mechanic
vulcan300's Avatar
Damaged threads on oil cooler
I recently removed the short flexible lines between the brass oil lines and the cooler in the front passenger side fender. The flexible lines separated fairly easily from the brass lines however they did not want to come off of the cooler. Several hours and much torching and sweating and swearing had them apart but the aluminum threads on the inlet and outlet are pretty much gone. I think they are beyond the help of a thread saver. What are my options?
Is there an adapter designed for this situation? I'm sure I'm not the first person this has happened to.
Or am I looking at a new cooler? Perhaps the aftermarket one offered by our host.
Please let me know your thoughts.
Thanks!
J
86 911 Carrera Targa
Old 04-12-2011, 09:41 PM
RETIRED
Joe Bob's Avatar
Cut and weld new ones on....
2012 ML350 3.0 Turbo Diesel
Old 04-12-2011, 10:09 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Threads on the cooler itself? Do you have a welder that can handle aluminum? I would take it to the radiator shop and pressure test it for insurance.
I was going to say try using aluminum foil like a teflon tape, I over torqued my wife's banjo bolt of the power steering high pressure hose. Stopped the leak.
'85 Carrera Targa
PCA/POC
Old 04-12-2011, 10:34 PM
Northern Motorhead
wildcat077's Avatar
Yeah,i would say to go to a radiator shop as well ...
They can brass weld new fittings,although it will most likely be difficult to find new ones.
I just had mine apart last weekend as i replaced my thermoswitch and changed the oil cooler seal.I used a torch and heated the crap out of the fittings before they came loose.
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-13-2011, 03:18 AM
Weekend Mechanic
vulcan300's Avatar
Thanks gents. Looks like the consensus is clear. I'll be heading to a radiator shop shortly then. DO you know what size the fittings are?
Old 04-13-2011, 06:18 AM
