Does a replacement exisit for this terminal?
This terminal has obviously shorted at some stage of its life. Keen to replace it - any thoughts? (From iginition switch to fuse box).
http://forums.pelicanparts.com/uploa...1302503810.jpg |
doesn't appear to be a factory item. try a trailer supply store.
Better yet, try to figure out why somebody used that and see if you can undo whatever they modified.
JR |
+1 on both suggestions so far.
I'm surprised - the other end of these wires that connects to the ignition switch appears to have all original connections.... Hmm back to the drawing board I guess then.
Do you suppose that a previous owner added this to allow him to have a simple anti-theft feature? Unplug the connector to "enable" the anti-theft "system".
JR |
Possibly. Just Behind the ignition switch. Thanks for the heads up gents - will be ripping that puppy out tomorrow!
That does not look like a trailer connector as those are either 4 wire or seven wire. The seven wire connector is a large round plug. Are there just the three male terminals on that plug? Here is a trailer connector for comparison
http://static.howstuffworks.com/gif/...r-wiring-3.jpg |
7 male, one female
| All times are GMT -8. The time now is 02:51 PM. |
