Always learning
Does a replacement exisit for this terminal?
This terminal has obviously shorted at some stage of its life. Keen to replace it - any thoughts? (From iginition switch to fuse box).
Old 04-10-2011, 11:37 PM
doesn't appear to be a factory item. try a trailer supply store.
206 637 4071
Old 04-11-2011, 05:07 AM
Better yet, try to figure out why somebody used that and see if you can undo whatever they modified.
JR
Old 04-11-2011, 05:45 AM
Recreational User
porschenut's Avatar
+1 on both suggestions so far.
Old 04-11-2011, 05:54 AM
Always learning
I'm surprised - the other end of these wires that connects to the ignition switch appears to have all original connections.... Hmm back to the drawing board I guess then.
Old 04-11-2011, 06:00 AM
Do you suppose that a previous owner added this to allow him to have a simple anti-theft feature? Unplug the connector to "enable" the anti-theft "system".
JR
Old 04-11-2011, 06:04 AM
Always learning
Possibly. Just Behind the ignition switch. Thanks for the heads up gents - will be ripping that puppy out tomorrow!
Old 04-11-2011, 06:13 AM
Friend of Warren
That does not look like a trailer connector as those are either 4 wire or seven wire. The seven wire connector is a large round plug. Are there just the three male terminals on that plug? Here is a trailer connector for comparison
Kurt V
Always learning
7 male, one female
Old 04-11-2011, 06:15 AM
