915 clutch arm orientation?
I just pulled the splined clutch release shaft out of my 915 to grease it.
Now that it's going back in, does the throwout arm line directly up with the arm for the clutch cable? It's a 915/02, no horseshoe spring or other stuff.
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
Todd, just give yourself a location where you have room to adjust the cable and have it make a difference so youre not pulling too hard. Just to the rear of a right angle to the clutch cable should do the job.
Bruce |
Thanks Bruce...I just got it all back together.
I had initially set it up that the the two arms lined up, but that was wrong. The clutch cable arm needed to be one spline further away from the cable to get full clutch release. A few hours ago I thought I was going to have to pull the engine and trans and reset the splines at the throwout bearing. Thankfully I realized it could be done at the arm as well...
