mycastle's Avatar
Targa Top Latch
Anyone ever try to "fix" a Targa Top Latch? There are two hooks on the latch, one of mine is not moving. When i try to remove the top, I turn the handle 90 degrees - then, turn it a little more against a spring pressure and the hook that is supposed to move at that point doesn't - hard to get the top off when that latch doesn't get out of the way.
Anyhow - took the latch off and it certainly does not look servicable. Any thoughts?
1978 911SC Euro
1970 914 1.7L Sold
1972 914 2.0L Sold
Old 04-17-2011, 05:45 PM
Member 911 Anonymous
DRACO A5OG's Avatar
There should be a spring acutator on the first hook, sounds like yours may have broken or jumped off, can you peak inside with tear it apart?
'85 Carrera Targa
PCA/POC
Old 04-17-2011, 06:01 PM
mycastle's Avatar
The spring seems to be working find. The bar that moves the hook does not seem to engage when I turn the handle. Can't see into that section. I imagine it is a cam on the shaft that the handle turns that should push the bar which should push the hook against the spring. So I think the problem is between the shaft/cam and the bar.
1978 911SC Euro
1970 914 1.7L Sold
1972 914 2.0L Sold
Old 04-17-2011, 07:49 PM
DRACO A5OG's Avatar
Contact Dan P and CarsincNJ.com he has used component for a Targa Babies.
I would open it and find the culprit since it appears to be toast anyways, maybe you can post a tutorial on a fix
'85 Carrera Targa
PCA/POC
Old 04-17-2011, 09:37 PM
