Jtt84911's Avatar
OK Automatic Heater Control Experts....Tell Me
Doing bunch of Winter projects...change 915 gear oil, install Coupler Whisper bushings etc etc. and since the console/shifter were out...I removed the automatic heat system to open it up and change the small light bulb that lights the temp dial (bulb's only been out for only 5 years)
Slid the temp selector knob off and saw this screw and YES of course I turned the screw to see if it moved... and NO.... I have no idea what the screw does !!
It rotates completely independent of the the "clicked" selector so I'm guessing it may used to set the temperature calibration??? Or maybe it controls how much the small arm pulls the two heater cables the open the heater boxes???
What does the screw adjust??
Thanks,
JT
Old 03-20-2015, 01:43 PM
Caledonian's Avatar
I'm no expert but here are some pics that may help answer your question.
Old 911 with new owner
Old 03-20-2015, 02:26 PM
wwest's Avatar
Look to me a lot like the type of adjustment that is done to make an electric oven control knob marker point to the actual regulated temperature.
Calibration: "5" should equal a cabin setpoint temperature of "NN" (72dF..??).
Old 03-20-2015, 03:22 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Calibration.
Thanks,
JT
Cabin temp calibration.
After setting the temp switch to 5, hold the shaft, and turn the screw to read 950 Ohms at the potentiometer contacts.
Page 806-7 of the Bentley.
G.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-20-2015, 04:38 PM
Sigh - I wish I could just get my auto heat to work. It's either All on high heat or totally off. At least in Atlanta it's not that big a deal.
'85 RoW 911 Coupe
'65 356 SC
'72 BMW 2002Tii
'10 Cayenne
'20 Ram Longhorn
Old 03-20-2015, 04:46 PM
Auto Heat.
Lots of threads on auto heat.
1986 911 Targa.
Only in L.A.:
Old 03-20-2015, 05:53 PM
El Duderino
tirwin's Avatar
The most likely reason is there is a thermistor in the rubber nipple that hangs above the rearview mirror. Either it has wiggled loose from the wire or the thermistor is bad.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 03-20-2015, 06:04 PM
Jtt84911's Avatar
wwest and 86 911 Targa _
THANKS GUYS - thought that's what it was.... but had no idea about the 5 setting for calibration!!
tomphot- tirwin is right,,,, there's lots of posts, If you start reading and checking you will definitely get it working. First step is determining if it's a mechanical or electrical issue. For example when you turn the knob to 7 for example do you hear the servo motor inside the control box running and then stop?? The rod that pull the cables which starts a chain reaction of a of other things.... may have popped off on one of the ends. (which you need to do BTW to remove the unit) There's two snap-in covers on both sides on the control unit. pop one off an look inside with a work light and see if the connecting rod is on. If not... and the black plastic socket connectors are OK....pop it back on. If its that issue....that's a 1 minute fix and the difference of the thing working or not working!!!
JT
Old 03-20-2015, 06:55 PM
Quote: {The most likely reason is there is a thermistor in the rubber nipple that hangs above the rearview mirror. Either it has wiggled loose from the wire or the thermistor is bad. }
Can you still buy the thermistor or are they NLA?
Rahl
Old 03-20-2015, 08:15 PM
El Duderino
tirwin's Avatar
They can be bought. I think there is some marking on it that identifies it. Seems like there is an autoheat thread that covers it. There is a test procedure for it.
Old 03-20-2015, 08:22 PM
An '86 will have a different cabin sensor, in the lower dash.
FWIW...
JR
Old 03-20-2015, 08:53 PM
Sensor.
Thermistor
Coupler
1986 911 Targa.
Only in L.A.:
Old 03-20-2015, 10:03 PM
Post.
Read my post.
1986 911 Targa.
Only in L.A.:
Old 03-20-2015, 10:05 PM
Years ago when I bought the car, I fixed the coupler which was broken. That got the system to at least turn on and off. In addition, before I started reading Pelican, I noticed that little rubber thing up by rear view mirror which I thought was an old cell phone microphone . I undid the screws, gave it few yanks and decided to leave it alone and reattached it. If it wasn't broken before I started, I'm sure I finished it off. I need to fix it properly.
'85 RoW 911 Coupe
'65 356 SC
'72 BMW 2002Tii
'10 Cayenne
'20 Ram Longhorn
Old 03-21-2015, 05:04 AM
