T transmission?
Someone told me that i should put a T(?) transmission on my 3.2 and it becomes a lot faster. What is this T transmission and should i change over to it?
I'm speculating that your car has a 8:31 R&P and maybe what the person is referring to is older trannies, not necessarily a T, but trannies from 72- to mid 75 with a 7:31 R&P. These will ‘awaken’ a car up, but you have to shift much faster and with a 3.2 it might be a tad too much.
72 911 Although it is done at the moment, it will never be finished. |
More info would be helpful, do you have a US or RoW car. What tires are being used? Stock rev limit? What is the car used for?
I have a 78 sc turbo look. So I have the wider tires. It's a 3.2 from germany with a steve wing chip. The exhaust is still sc but everything else is stock 3.2
be specific what rear tire? x brand & www/aa x dd size what redline? xxxxrpm is this a track car? street car do you care about rpm in 5 on the highway?
Im sorry, I have the mechanical awareness of an ape. I don't know the exact dimensions of the tires right now. But the sw chip brought the redline to 6820. Its a street car, and my primary goal is reliability and drivability. I would like something fast but it would still need to take me to work everyday without being dificult
The T transmission might be the base 4 speed rather than the optional 5 speed. Not sure how much that would help. Not sure I would trust the advice of the person who said that either.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
I didn't trust him originally either but then he said that his mechanic said that, which also happens to be my mechanic, who definitely knows his stuff. He said it has 4 and 5 speed options
Pretty sure Bill needs the wheel/ tire size so he can plug the info into an app which will spit out what mph your car wil be travelling at what rpm/ etc...
given what you use the car for you are 95% certain to want to keep what you have
Ok I see kuhmo ecstasy rear wheels are 225/50r16
Front are 205/55R16 |
Ecsta asx*
auto correct... |
OK if the guess that your mechanic was suggesting a 911 TS transmission to perk up the acceleration of you car is correct
here is a stock 1978 SC trans w/ the redline and tires you are using ![]() and here is your can w/ a 1972 911T/ES transmission ![]() The lower the speed in a gear the better the acceleration and the higher th rpm will be at cruise. So yes the car will accelerate better in any gear. The question is are you willing to pay for the increased acceleration? It can be done but it won't be a real cheap swap.
Wow thanks for that! What is that app and how can I find it?
Im not sure what i'll do, id have to check it over with him first. I also don't want to lose on the top speed end but we'll see |
