Coated headers
I like this....
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
That looks like aluminized coating ? My boat headers were done like that back in the late 70's. Where is that getting done & expensive ?
It is ceramic. Swain coatings, not too expensive, I haven't seen the final price but under $300
6 cylinder symphony
nice.
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
Looks great post final product for us.
Tony 91 964 c2 black/ Work in progress/Finally back on the road 85 EURO 930 Black slightly moded slowly reviving her 77 911tt EFI wide body red/ Slightly modified ![]() SOLD
Is it durable (will not crack if it got banged / dropped) ??
Baked on at 3000 degrees. supposed to be really durable.
AutoBahned
what problem does it solve for $300?
The idea for crowded engine compartments with V8s is to reduce underhood temperatures for cars with cooling issues (my old 74 corvette..it worked on the track) and supposedly create less local heat for crammed engines....especially when one builds equal length headers that take up more space and cook spark plug leads and accessories (AC cobra, MB 450 SLC 5.0).
I don't know what it does for 911s other than esthetics, perhaps others have some insight.
1988 Carrera Coupe |
Were the interior walls of the exh. tubing also coated? If so, that might actually mummify (preserve) the entire exh. system. Sherwood |
Max Sluiter
It would have more benefit on a turbocharged engine. More heat (energy) stays in the exhaust gas flow, increasing velocity and meaning more energy to be recaptured by the turbine, and so quicker spool, too.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Thermax temp. sensor on exhaust valve cover. About 260ºF: ![]() CU: ![]() If exh. temp. is reduced, the temperature in this area will also be reduced. Does it register on the oil temp. gauge? No or hardly. Consider the engine cooling system has add'l cooling capacity - i.e. more headroom. Ceramic coating is a relatively recent technology. The factory used heat shields in selected engines. Here's an example on a GT2 engine. I would imagine modern race engines use titanium or inconel exhaust tubing for this purpose: ![]() Sherwood |
I live in Alabama. I don't care how fast you are going, the air is thick enough to slice in the summer. I want this engine to run cool, (3.6) and last a long time. This is my plan. Plus, it looks fantastic and 100x better than those rusty headers. I looked with the light in the header and they did a pretty good job coating in the inside.
They claim 30 to 50% reduction in heat. We will see. I have had cooling issues with this motor even with additional cooler and duct cut in the tub. The rest of the exhaust is jet hot coated. The heads and pistons are being coated too plus bigger valves.
I'll be interested in your info/impression of any advantages to coating the heads (combustion chambers ?), since I had a bunch of coatings done to my engine (2.7L), which I will be eventually installing it in my car. I had the piston tops, combustion chambers, valve faces< & exhaust ports coated. Plus, I also have a set of coated headers to use. I had a lot of stuff dry film lubricant coated also and wonder if that might help with cooling somewhat.
Marv Evans '69 911E |
Vintage Motorsport
Coating technolgy will give you a few bhp. Coatings will also increase component longevity. I'm working on a new column for Vintage Motorsport magazine. The more I learn the more I'm impressed. NASCAR is the leader in this area. That's why we're getting so many F1 guys working in North Carolina. Concorde is the place to learn about cutting edge coatings.
Richard Newton '73 911 Last edited by RichardNew; 04-27-2011 at 08:55 AM.. Reason: spelling |
Marv, I haven't run anything yet as the heads and pistons are just getting sent off. My machine shop guy, who builds a lot of drag motors and roundy round motors, said he is not too sure on the bearing coatings but feels that the anti friction coatings on the pistons are very good. The head coatings are not that much compared to what the head work is going to cost. I figure that this will be a good test mule for some other motors that I am working on.
Swain is probably the best coating company on the market. Sure you don't all that shiny cool looking coatings that the other companies have, but what you get is something that works. I have a DP coated with it and after I run the car I can literally touch the pipe with out melting my skin to the exhaust. Pretty cool stuff, no pun intended.
72 911 Although it is done at the moment, it will never be finished. |
Under the radar
I had my heat exchangers and muffler aluminum sprayed 20+ years ago. NO rust yet on the muffler, the heat exchangers are starting to show a couple of rust spots.
Cost was ~$300 at the time. Way cheaper than stainless. So for corrosion resistance it's cost effective.
