Adjustable heel-toe pedal?
I went to a DE event this past weekend and the guy beside me had an adjustable heel toe gas pedal. It mounted on an adapter base that mounts to the stock pedal and had side to side and up and down adjustments. Has anyone seen thease and know the source of them. The shape was a backward L and the surface of the pedal was smooth aluminum with holes in it and had three screws attaching it to the adapter. It was just the gas pedal. Brake and clutch pedals were stock. Please let me know.
Duane
'03 M3 Coupe, '65 Mustang 2+2, '72 Cherokee 140
Old 02-21-2002, 07:48 AM
Send a message via AIM to 82SC
i thinkI know what you are tlaking about...
check the back of Excellence mag...Ithink that company usually runs an ad there...
also check out AJ-USA.com I think they might carry them too...
MJ
Old 02-21-2002, 07:56 AM
gumba's Avatar
The company is called Wings Engineering in Ct. tel. 203-438-2222, fax 203-431-8792. I've been using one for the past year, it's great. $99 for the standard ( I have) $105 for x/wide . Takes about 5 min. to install and can adjust it while sitting in drivers seat.
Old 02-21-2002, 08:59 AM
