-   -   Removing front strut inserts (http://forums.pelicanparts.com/porsche-911-technical-forum/605560-removing-front-strut-inserts.html)
toddu 04-28-2011 10:33 AM
I'm replacing my front torsion bars as well as taking out the strut inserts to get them revalved.
I've had the struts completely off before, as well as the a-arms.
If I don't plan on removing the a-arms, or even disconnecting the struts (hoping I'll have enough room to swing the top of the struts out past the fender so I can get the inserts out), is it more beneficial to remove the torsion bars first, or leave them in while I take the inserts outs? Seems like it would be one less thing to fight with if I take them out.
Car is completely off the ground (on a lift).
Thanks!!
Todd
arbita1 04-28-2011 10:47 AM
I did my strut insert replacement that way (these were Boge struts). I'm pretty sure the torsion bars were installed at the time. I don't think it would make a difference either way.
schumicat 04-28-2011 11:00 AM
you should have more than enough room to clear the fender. you will need to compress them a little, which isn't that hard. I replaced mine by undoing only the single top bolt.
algs911 04-28-2011 11:05 AM
It's been a long time, but I think I had to remove the brake caliper because my brake lines were too short to swing the top of the strut out. It's not a big deal at all to do this.
Al
trconway 04-28-2011 11:25 AM
strut replacement
I replaced mine without removing anything else. Keep in mind you will have to compress the new strut to swing it back into place. Provides some exercise!
