911mnypt's Avatar
Euro 3.0 cam timing ranges
Lost my notes and can't remember the cam timing ranges for a 1980 euro 3.0 motor?
Thanks,
Richard
P-car no more
2000 F250 Powerstroke Crew cab "Growler"
2007 Honda Odyssey "The Bus"
2006 BMW 330i Manual 6 speed "The Sled"
1987 Mercedes 560SL
Old 05-01-2011, 01:48 PM
Bill Verburg's Avatar
Thanks,
Richard
'76 & 77 C3 used the most retarded timing spec for intake opening initiation @ 1* BTDC, retarding the cam timing theoretically helps top end hp
Some of the SC's used as much as 7* BTDC, advancing the cam timing theoretically helps bottom end torque
'84-89 Carrera 3.2 split the difference @ 4* BTDC
For the '78 - 81 SC's it depended on the year and engine installed
930/04,05,15, 06, 10 were @ 1* BTDC
930/03, 13, 07, 08, 09, 19, 16, 17 were @ 7* BTDC
Bill Verburg
Old 05-01-2011, 02:03 PM
911mnypt's Avatar
Thanks Bill for taking the time to respond and useful info!...sorry if I was not clearer with my question. I am re-installing my cams and wanted to advance them a little. I can't remember the mins / max on the ranges. I think the stock SC motor is 0.9 - 1.1 mm?
P-car no more
1987 Mercedes 560SL
Old 05-01-2011, 02:33 PM
euro spec is 1.4 to 1.7 if i remember right. spec book is at the shop.
206 637 4071
Old 05-01-2011, 04:02 PM
911mnypt's Avatar
That sounds about right, however if you can verify tomorrow I would appreciate it!! I think you actually gave me these specs about 1.5 years ago, however my dog ate my notes...
Thanks,
Richard
P-car no more
1987 Mercedes 560SL
Old 05-01-2011, 04:24 PM
If you want all the power in the high end as the euro s do use .9 if you want street power off the light use the 1.7.
Bruce
Old 05-01-2011, 06:04 PM
911mnypt's Avatar
I am running weber's so I am curious to see how this all comes into play...especially after the distributor re-curving is done.
Thanks,
Richard
P-car no more
1987 Mercedes 560SL
Old 05-01-2011, 06:14 PM
went by the shop for a sec. 1.4 to 1.7 it is.
206 637 4071
Old 05-01-2011, 06:50 PM
911mnypt's Avatar
THANK YOU VERY MUCH!
Richard
P-car no more
1987 Mercedes 560SL
Old 05-01-2011, 07:05 PM
