2002 996 C4S
jcsjcs's Avatar
Clutch Smell
Hey all -
84 911 Targa.
Had my transmission rebuilt last year and replaced the clutch (myself.)
The car is shifting GREAT now. They only issue is an "asparagus" smell when I start up FAST in 1st gear. Have probably driver 750 miles on the new setup.
A friend also had the same problem under normal acceleration when he was trying out my car recently - but I think that was related to him learning where the clutch engages.
Should I be concerned? Could this simply be a new clutch breaking in OR could it be a required clutch cable adjustment?
NOTE: I also replaced the Alternator Belt recently - had the problem BEFORE and AFTER the replacement and the belt seems to be the right "tightness." Have heard that a slipping Alternator Belt can cause a similar smell. I don't think that is my problem (but am open to input....)
Thanks - jcsjcs
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 04-29-2011, 10:36 PM
Member 911 Anonymous
DRACO A5OG's Avatar
you should not smell the asparagus unless you slip the clutch. i would check the adjustments below,
where does the clutch engage on the pedal?
'85 Carrera Targa
PCA/POC
Old 04-29-2011, 10:43 PM
2002 996 C4S
jcsjcs's Avatar
I followed 101 Projects for the clutch adjustment and I believe it helped.
The gap at the positioning lever was 1.2 mm without the clutch cable. It was NOT 1.0 mm when I put on the clutch cable. After some messing around I was able to get it to 1.0 mm. I am guessing that this puts necessary pressure on the clutch mechanism to show that it is "ready to go."
I also could not get the 25 mm gap change in the cable worked out because I don't have a rubber stop behind my clutch pedal! $2.25 and I will get one... does someone have a picture of how this is setup?
jcsjcs
Have: '02 996 C4S
Old 05-01-2011, 06:12 AM
