Have anyone tried this...
...for leaking window seals?
Capt. Tolley's Creeping Crack Cure
Old 04-26-2011, 09:16 AM
Almost Banned Once
sc_rufctr's Avatar
Looks interesting but it may be just easier to get some new seals and swap them out.
- Peter
Old 04-26-2011, 09:21 AM
Peter why would it be easier? I´ve been reading that it takes about 4 guy´s 4-5 hours to take out the window and replace the seals. Or about 400$ to have someone do it here in Norway where i live.
I would guess lubing up the seals with this takes about 30 min and cost 10 bucks
Old 04-26-2011, 09:25 AM
Scott R's Avatar
This is an old trick that auto re conditioners use. Fill the joints with with a compound to make them look new again. The problem is that the cracks will continue to spread and you will be back to the way it was before, if not worse in a few months. In fact I've seen shoe polish used to do this, and just about every other type of filler.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-26-2011, 09:42 AM
@scot, are you reffering to cracks in the window glass? I was more thinking on leaks in the rubber seal and not in the glass...
Old 04-26-2011, 09:49 AM
Scott R's Avatar
No, rubber gaskets. You put filler material in them and they just expand again when they get warm or cold, crack gets bigger around the filler compound. Filling is just a temporary cosmetic fix really. Should just replace the seals as suggested above.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-26-2011, 09:58 AM
Sorry for being slow, Scot. But I actually do not understand what you mean! I have a old rubber seal around my rear window that leaks... So no need for cosmetic work, but need for stopping a somewhat hidden leakage... Offcourse changing the seal would be the best. However do you mean that I should NOT use Tolleys at all for this purpose?
G
Old 04-26-2011, 10:21 AM
1978 911sc coupe
G
Glennhm, I had the exact same problem with my first 911. I used a small amount of "Sika rutetett" under the lip of the rubber seal all the way around. Problem solved!
I have not seen it in the hardware-stores. Got mine from the local professional car-glass shop.
You can check out the product sheet here: Sika Norge AS | Produktdata
Kjell
Old 04-26-2011, 11:26 AM
@Kjell: Takker: Sika er nå bestillt
Old 05-02-2011, 12:44 PM
