ffilips's Avatar
Send a message via ICQ to ffilips
Question changing from boge to koni struts
I have a 69 911t which has boge struts on the front. I would like to firm up the ride, and since my existing shocks are of questionable age, I am wanting to swap themout for a set of koni's. Are there any problems with doing this? Are ther any modifications I will need to make? I've already run a search but no one addresses this year of 911.
Thanks in advance.
69 911t
86 951
Old 02-22-2002, 10:35 AM
Early_S_Man's Avatar
Porsche Crest
you may want to consider replacing your ball-joints, rebuilding your calipers, replacing rubber brake lines, and installing Turbo tie-rods at the same time.
I usually recommend removing the struts from the car, and cleaning and re-painting them before installing the new inserts. A special tool may be need to be fabricated to install the Koni cap nut ... Haynes has a diagram, but I am not sure if it is needed with Boge struts.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-22-2002, 12:21 PM
