Wer bremst verliert
JohnJL's Avatar
Oil lines through the tunnel?
For you guys who are running wider tires, is it common practice to run the oil lines from a front cooler through the tunnel? I have the fuel lines, battery +cable, clutch hose (G50 trans) and an accelelerator cable (ditched the linkage) through there already. Harget shifter means no linkage through the tunnel excapt at the rear bulkhead. I think I can get them to fit, any other suggestions?
Track car only, no interior so my fallback was to run them straight through the rear bulkhead, under the passenger seat (weld in some sheilding near the pass feet) and straight up front to the mocal cooler.
Appreciate the help.
John
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 05-06-2011, 08:17 PM
RETIRED
Joe Bob's Avatar
I'd run them inside the car along the passenger side.....the tunnel is a bit busy.....
2012 ML350 3.0 Turbo Diesel
Old 05-06-2011, 08:34 PM
