-   -   69-73 front bumper mounting & support Qs (http://forums.pelicanparts.com/porsche-911-technical-forum/606806-69-73-front-bumper-mounting-support-qs.html)
deathpunk dan 05-05-2011 07:09 AM
Hello
My front bumper is attached to the car only by the four bolts (2 on each side) that go from the front trunk area (near the headlights/battery boxes) into the brackets attached to the bumper (with the captive nuts).
There are no other brackets attached to and it is not supported anywhere else. As a result, it hangs down awkwardly at the outer edge (where it terminates at the wheelwell) on both sides.
Should there be some sort of support bracket on each side? Looked at a 67S and it had support tubes in this area. But my understanding is -68 have a different setup.
I'd really like to fix this. Any advice or info is appreciated.
ossiblue 05-05-2011 08:29 AM
Yes, there is a support bracket that attaches to the side of the battery boxes. The bracket is shaped like this, ] with the top and bottom "legs" as attachment points for bolts--the top leg for the fender, and the bottom for the bumper. The bumper itself should have a welded bracket that will bolt to the support bracket.
tharbert 05-05-2011 08:32 AM
And it's a significant piece of metal on mine, maybe a bit less than 1/4" bar stock?
m1franck 05-05-2011 09:12 AM
Then if you do a battery box delete in order to add a fender mounted oil cooler you can build a bracket something like this to replace the one that was attached to the battery box. Before and after
http://forums.pelicanparts.com/uploa...1304611909.jpg
http://forums.pelicanparts.com/uploa...1304611937.jpg
m1franck 05-05-2011 09:26 AM
Also, here's what the corresponding bracket looks like on the inside of the front bumper, albeit this is a fiberglass bumper I'm sure a stock steel one has something similar.
http://forums.pelicanparts.com/uploa...1304612911.jpg
deathpunk dan 05-05-2011 10:44 AM
Aha!
Ok....the bumper itself does have the inside brackets. And the battery boxes are still present and have the holes. So I just need to find the fasteners and correct legs or make something.
Thank you all for the descriptions and photos!
