-   -   RPM drop while checking the oil?? (http://forums.pelicanparts.com/porsche-911-technical-forum/606961-rpm-drop-while-checking-oil.html)
Brown747 05-05-2011 10:35 PM
Getting to know my new SC.. One thing I have noticed is that while checking the oil there is a noticeable drop in RPMs after removing the oil cap. Maybe 150 RPMs. Is this normal or an indication of something that needs further attention?
TJ
Noah930 05-05-2011 11:05 PM
Normal. You've just created a vacuum leak by opening the filler cap.
JJ 911SC 05-06-2011 04:05 AM
Your first mystery solved ;)
To the next one...
Brown747 05-06-2011 10:12 AM
Thanks!
MH911 05-06-2011 10:15 AM
When the RPM's don't drop, that's when their is a problem.
kidrock 05-06-2011 03:34 PM
RPM's dropped when you removed the oil cap? That's GOOD news.
Fuhgeddaboudit.
JJ 911SC 05-06-2011 04:01 PM
Fuhgeddaboudit.
Stone
Where have you been?
dshepp806 05-06-2011 04:43 PM
I almost threw my oil restrictor away by not paying attention, many years ago, while working on the car. That drop is RPM drop is quite normal (and expected, as stated).
BEST!
Doyle
Carrera3.2LG50 05-06-2011 05:01 PM
That restrictor is in the hose at the top of the oil tank near the filler neck. If it is not there, your engine will stall every time you try to check the oil. I learned about this last year when I had some hoses replaced at the shop - they left the restrictor out by mistake.
kidrock 05-07-2011 03:45 PM
Originally Posted by JJ 911SC (Post 6007042)
Stone
Hey JJ, I've been lurking. Just stepping back to let the REAL experts chime in. I've stepped on my own d i c k a couple of times giving advice lately. ;)
JJ 911SC 05-07-2011 04:14 PM
C'est la vie...
Glad to come across your postings again SmileWavy
kidrock 05-07-2011 08:23 PM
Originally Posted by JJ 911SC (Post 6008565)
C'est la vie...
Merci, mon ami. SmileWavy
