RPM drop while checking the oil??
Getting to know my new SC.. One thing I have noticed is that while checking the oil there is a noticeable drop in RPMs after removing the oil cap. Maybe 150 RPMs. Is this normal or an indication of something that needs further attention?
TJ |
Driver
Normal. You've just created a vacuum leak by opening the filler cap.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
83 911 Production Cab #10
Your first mystery solved
![]() To the next one...
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Thanks!
1978 SC coupe #1834 |
When the RPM's don't drop, that's when their is a problem.
Kipp 1987 Black 911 3.2 Carrera Coupe 1999 Green Mazda MX5 (SOLD) |
muck-raker
RPM's dropped when you removed the oil cap? That's GOOD news.
Fuhgeddaboudit.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Where have you been?
I almost threw my oil restrictor away by not paying attention, many years ago, while working on the car. That drop is RPM drop is quite normal (and expected, as stated).
BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
That restrictor is in the hose at the top of the oil tank near the filler neck. If it is not there, your engine will stall every time you try to check the oil. I learned about this last year when I had some hoses replaced at the shop - they left the restrictor out by mistake.
muck-raker
Hey JJ, I've been lurking. Just stepping back to let the REAL experts chime in. I've stepped on my own d i c k a couple of times giving advice lately.
Glad to come across your postings again
muck-raker
Merci, mon ami.
